I run OSMC on a PI3 connected to an oldschool CRT TV which has only a MONO audio input so I’d like to configure OSMC to output MONO audio. This means L+R are mixed together in both audio channels.
I’ve been looking a lot on settings for this usually easy option with no luck. Is that possible at all? Maybe with a plug-in?
Yes but a software solution would be cheaper and neater. Also adding to the signal could introduce noise or reduction, software would be much better. In the same link they also suggest to change some ALSA settings. Now I can set ALSA as output in OSMC but I can’t find any of the files they suggest on the topic. Isn’t ALSA insalled by default in OSMC?
ALSA is there all right. Make a file called .asoundrc in /home/osmc with the contents suggested but adding a hint
# mono
pcm.mono {
type route
slave.pcm "hw:0,0"
ttable {
0.1 1
0.0 1
1.0 1
1.1 1
hint {show on description "Mono analog"}
You may also have to type this sudo amixer cset numid=3 1 not too sure.
Restart kodi and you will see an extra entry in the audio settings. It won’t say “Mono analog” (getting too late for me to work out why) but if you experiment you should find one setting that gives you mono output.
