Without installing sabnzbd, it’s difficult to say, but you ran pip3 install puremagic, which is for python3. See if pip install puremagic (for python2) helps.
Yeah, I had tried that too but no go.
I checked out the thread you linked to and I see that you are unable to see puremagic even when you’re inside python3. I don’t have that problem:
osmc@osmc:~$ pip3 install puremagic
Collecting puremagic
Using cached https://files.pythonhosted.org/packages/d5/6e/62d1cef9a0d8edf2d9c44b0a1b91b0b29b66fb693c94af278a0c76ddfd8c/puremagic-1.10-py3-none-any.whl
Requirement already satisfied: argparse in ./.local/lib/python3.7/site-packages (from puremagic) (1.4.0)
Installing collected packages: puremagic
Successfully installed puremagic-1.10
osmc@osmc:~$ python3
Python 3.7.3 (default, Jan 22 2021, 20:04:44)
[GCC 8.3.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> import puremagic
>>> puremagic.__file__
'/home/osmc/.local/lib/python3.7/site-packages/puremagic/__init__.py'
>>> puremagic.__version__
'1.10'
>>>help('puremagic')
Help on package puremagic:
NAME
puremagic - # -*- coding: utf-8 -*-
PACKAGE CONTENTS
__main__
main
DATA
magic_footer_array = [PureMagic(byte_match=b'\x00\x00\x01\xb7', offset...
magic_header_array = [PureMagic(byte_match=b'\x00\x00\x00\x00\x00\x00\...
VERSION
1.10
AUTHOR
Chris Griffith
FILE
(END)
Clearly, something is a bit borked on your instalation. Try to uninstall and reinstall the puremagic module.
Really don’t know. Tried as suggested.
osmc@HTPC:~$ pip3 uninstall puremagic
Found existing installation: puremagic 1.10
Uninstalling puremagic-1.10:
Would remove:
/home/osmc/.local/lib/python3.8/site-packages/puremagic-1.10.dist-info/*
/home/osmc/.local/lib/python3.8/site-packages/puremagic/*
Proceed (y/n)? y
Successfully uninstalled puremagic-1.10
osmc@HTPC:~$ pip3 install puremagic
Defaulting to user installation because normal site-packages is not writeable
Requirement already satisfied: puremagic in /usr/local/lib/python3.8/site-packag es (1.10)
Collecting argparse
Using cached argparse-1.4.0-py2.py3-none-any.whl (23 kB)
Installing collected packages: argparse
Successfully installed argparse-1.4.0
osmc@HTPC:~$ python3
>>> import puremagic
File "<stdin>", line 1, in <module>
ModuleNotFoundError: No module named 'puremagic'
You didn’t use sudo did you?
Okay. Got it:
osmc@HTPC:~$ python3 -m pip install puremagic
Cache entry deserialization failed, entry ignored
Collecting argparse (from puremagic)
Using cached https://files.pythonhosted.org/packages/f2/94/3af39d34be01a24a6e65433d19e107099374224905f1e0cc6bbe1fd22a2f/argparse-1.4.0-py2.py3-none-any.whl
Installing collected packages: argparse, puremagic
Successfully installed argparse-1.4.0 puremagic-1.10
>>> import puremagic
ive been searching around the forums and i cant quite understand the autostart in debian. can someone explain how to autostart sabnzdb. i did see the wiki but im not understanding im a Arch user typically.
To make the service autostart it would be
sudo systemctl enable sabnzbdplus
success!
i did see that command and tried it before but it didnt work. this time i ran the command and did a restart right away and it loaded this time.
thanks
just wanted to share my sabnzbd experience on the Vero4k box.
im just using the debian repo version which i think is 2.3.7. no issues. would be nice to have current version but im ok for now.
it does fine processing files. even very large files of course not fast but it gets the job done and even while im watching movies i dont notice any lag.
for a easy way to set options in sabnzbd i seen a few instructions on editing files but i think the best way is to just open a browser and type in your verok ip/port/sabnzbd and set them all thru your browser. make sure to launch sab 1st by ssh in to your box and type sabnzbd.
anyone have experience running several services like radar and sonar all that once? any issues watching movies while all those are running in background?
im still having some issues with the autostart of sabnzbd. i have to retype sudo systemctl enable sabnzbdplus every so often. overall if i dont restart the box it holds.
overall this is a great setup to have. vero4k is one of my best purchases ive made
Thank you for your kind words.
I run sab/sonarr/radarr and sab can cause OOM when downloading/unraring large 4k files. I tend to pause jobs when watching content to try to avoid this. Sonarr & radarr seem to have little effect on the 4k.
I would update Sab iif I were you as latest versions use python3 and therefore use less sys resources.
Check on Sab forums regarding autostart
@sam_nazarko do you think you would ever add programs like sabnzbd and radarr to the app store? is it much trouble to keep them updated?
thanks
I don’t plan to do this because they seem to have a number of issues when updating. They also seem to have their own distribution methods (i.e. not in Deb packages).
are there any repos available for sabnzbd? or just manual install for latest build? if so anyone have some instructions for that? tried looking over at the sabnzbd forums and couldnt find anything related to a repo debian users can use.
