If all of your clients use systemd, then
sudo apt-get install systemd-journal-remote is probably the best way
Otherwise you can use rsyslogd which is quite popular.
There are other alternatives like Logstash too.
Not that I’m aware of. This is a bit beyond the scope of this forum however
Yes, but only a little bit.
I installed syslog-ng which brought with it the necessary systemd service file and started syslog-ng. I had to add a configuration file to handle the incoming syslog entries:
$ cat /etc/syslog-ng/conf.d/remote.conf
source net { syslog(ip(192.168.1.25) transport (“udp”)); }; <==This won’t work!
source net { source net { udp(); }; <==Use this instead
destination remote { file(“/var/log/remote/${FULLHOST}-log”); };
log { source(net); destination(remote); };
Where 192.168.1.25 is the LAN address of the ATV server where the syslog-ng server is listening for connections from the syslog clients of LAN devices.
NOTE: Use this entry instead
or syslog-ng will fail to start on a reboot if you specify an IP address to listen for connections. Perhaps it wants the ethernet interface to be up and running before it will start. Not sure.
Each LAN host sending its logs to the syslog-ng server will generate a log file prepended with its IP address within /var/log/remote/. I had to create the /var/log/remote directory manually and chown it to root:adm.
I have not yet installed logrotate or configured a cron job to rotate syslog-ng generated logs. Is this something that systemd will do on its own along with the journal file, or will it require my intervention?
Regards,
Mick
You need logrotate. The package sets up a systemd-timer
Thank you Sam,
Installing logrorate brought cron with it, installed /etc/logrotate.d/syslog-ng and also set up a daily cron job. All I had to do is add an entry for /var/log/remote/*-log in /etc/logrotate.d/syslog-ng.
This looks good and was much simpler than I thought. Thank you for your help!
Regards,
Mick
PS. The only thing I noticed when installing logrotate was this message about update-rc.d:
Preparing to unpack …/logrotate_3.8.7-1+b1_i386.deb …
Unpacking logrotate (3.8.7-1+b1) …
Processing triggers for systemd (215-17+deb8u6) …
Setting up cron (3.0pl1-127+deb8u1) …
Adding group `crontab’ (GID 113) …
Done.
update-rc.d: warning: start and stop actions are no longer supported; falling back to defaults
Setting up logrotate (3.8.7-1+b1) …
Does falling back to defaults means systemd unit files will be used to start cron?
No – it means the maintainer hasn’t provided a systemd unit for their package, so rc.d is effectively a legacy shim
It will all work fine
