how to reset system uptime on vero 2
Reboot.
I think he means the uptime reported by Kodi. You can delete Kodi’s userdata for this.
I.e. rm -rf ~/.kodi/userdata. But be aware you may lose some data here. I think uptime is stored in guisettings.xml, so you may get away with just deleting that file
Thanks I deleted the guisettings.xml and it reset
