Hello guys where do i set my ip to static in the osmc configuration
Try this solution (RaspberryPi), although it will be different depending on which hw platform and Debian OS version you are using for OSMC,
or this
Settings - My OSMC - Network - and then either Wired or Wireless depending on how you are connected
… hmm didn’t realise those OSMC menu/config settings were static.
As far as I understand, you set a static ip adress in your router.
Most routers allow dhcp reservation, but setting a static IP is done on the client device. The way @fzinken suggested is the recommended way.
Regards Tom.
