Hello everybody!
First time ‘poster’ here… ![]()
Beg your pardon if somehow I do a mess on explaining myself…
Without adue:
I am trying to set up a remote control for this usb dvb-t dongle here:
07ca:a835 AVerMedia Technologies, Inc.
The dongle works fine for tv reception, but I cannot use its remote control inside osmc.
This is what I get if I use ir-keytable command without any arguments:
$ ir-keytable
Found /sys/class/rc/rc0/ (/dev/input/event2) with:
Driver dvb_usb_af9035, table rc-empty
Supported protocols: NEC
Enabled protocols:
Name: AVerMedia AVerTV Volar HD/PRO (A
bus: 3, vendor/product: 07ca:a835, version: 0x0203
Repeat delay = 500 ms, repeat period = 125 ms
I have been trying to use lirc but I seriously have my doubts if I am heading the right way…
I managed to get to the point of creating a configuration file which I am trying to use right now:
# Please make this file available to others
# by sending it to <lirc@bartelmus.de>
# this config file was automatically generated
# using lirc-0.9.0(devinput) on Sun Mar 5 18:41:10 2017
# contributed by
# brand: config.conf
# model no. of remote control:
# devices being controlled by this remote:
begin remote
name config.conf
bits 56
eps 30
aeps 100
one 0 0
zero 0 0
pre_data_bits 8
pre_data 0x0
gap 499959
toggle_bit_mask 0x0
begin codes
KEY_POWER 0x04000400000501
KEY_AUDIO 0x04000400000513
KEY_PLAYPAUSE 0x04000400000516
KEY_STOP 0x04000400000518
KEY_FASTFORWARD 0x0400040000051D
KEY_REWIND 0x0400040000051C
KEY_RECORD 0x04000400000517
KEY_EPG 0x04000400000515
KEY_DISPLAYTOGGLE 0x0400040000054D
KEY_VOLUMEUP 0x04000400000504
KEY_VOLUMEDOWN 0x04000400000505
KEY_CHANNELUP 0x04000400000502
KEY_CHANNELDOWN 0x04000400000503
KEY_1 0x04000400000509
KEY_2 0x0400040000050A
KEY_3 0x0400040000050B
KEY_4 0x0400040000050C
KEY_5 0x0400040000050D
KEY_6 0x0400040000050E
KEY_7 0x0400040000050F
KEY_8 0x04000400000510
KEY_9 0x04000400000511
KEY_0 0x04000400000512
KEY_BACK 0x04000400000507
KEY_MUTE 0x04000400000506
KEY_MENU 0x04000400000508
end codes
end remote
I loaded this set up from ‘MyOSMC → Remotes’ menu. (tried both with disable RC6 on and off)
So, my question is:
Am I going in the right way to set it up? Is there a guide which I could follow to make it work (I mean loading and making this configuration file work inside osmc)?
Thank you already for your attention…
Followind advice from fellow @ActionA from the #irc channel, I am updating this post with pertaining dmesg content after (un)plugging the device to its rasperry-pi b+ host:
Thanks again for any insight and for having read thus far… ![]()
