Yes, save the file and exit the editor. Then do step 4.
If you’re using nano
as a text editor, press Ctrl
+ O
to save the file after you’ve edited it. The commands available via Ctrl
are displayed at the bottom:
Also make sure you open the file with sudo nano /etc/apt/sources.list
, else you won’t be able to save your edit.
Thanks! I will try it later
Am I reading this wrong or is this a workaround to get a non HDR amp to passthrough HDR?
You are not reading it wrong. We don’t know if all non-HDR AVRs can be spoofed, though. YMMV.
Note: it won’t make your AVR handle 4k60Hz if it doesn’t already. You might get HDR at 1080 or possibly 4k24Hz.
Thanks, i was convinced my amp passed through up to 4k30 but turns out that was my old one and this only does 1080p. Oh well, HDFury it is.
Once I save the file and I run this command
“sudo apt-get update && sudo apt-get dist-upgrade && reboot”
I get this message
osmc@osmc:~$ sudo apt-get update && sudo apt-get dist-upgrade && reboot
E: Type ‘sudo’ is not known on line 11 in source list /etc/apt/sources.list
E: The list of sources could not be read.
osmc@osmc:~$ apt-get update && sudo apt-get dist-upgrade && reboot
osmc@osmc:~$ E: Type ‘sudo’ is not known on line 11 in source list /etc/apt/sources.list
-bash: E:: command not found
osmc@osmc:~$ E: The list of sources could not be read.
osmc@osmc:~$ osmc@osmc:~$
Am I doing anything wrong?
Please post the output of:
cat /etc/apt/sources.list
Thanks Tom.
Hi.
I can’t seem to find the TV Category even if I press settings.
Where is this located?
Thank you.
Just to make sure: You do own a Sony 4k x900 TV for which karl posted this instruction, right?
If not, please describe your poblem. Doesn’t it properly display HDR content?
Hello,
I’ve just purchased a Vero4k+ and used the force_hdr to activate HDR though my Yamaha RX-v577 which only supports 4k passthrough.
It works fine but when restarting the Vero it seems that the force_hdr is not persistent.
Is there a way to make this change permanent ?
Thanks.
Ok thanks for the quick reply, I’ll do that.
