Since some time ago I started getting hdr content, but my TV (Sony 4k x900) doesn’t switch to hdr content, and actually if I enable it myself it s too shinny. Is there any manual or how to for dummies that helps to enable hdr content in your TV from vero4k
On the supplied remote control, press the HOME button.
Select Settings.
Under the TV category, select External Inputs.
Select HDMI signal format.
Select the appropriate HDMI input.
Select Enhanced format.
Your TV may do HDR but your AVR does not. Check by plugging vero direct into the TV instead of through the Onkyo.
There is a way round this but it needs some work with the commandline as it’s experimental. Let us know if you are up for that and we can post instructions.
Add the following line: deb http://apt.osmc.tv stretch-devel main
Login again and type echo 1 | sudo tee /sys/class/amhdmitx/amhdmitx0/force_hdr
Play some HDR material and see if your TV reports that it’s receiving HDR (it should say HDR or PQ).
