Hi, I’ve set up samba on the my osmc raspberry pi B+. Connected to my Pi is an external drive with several folders on it including on containing all my media files, how do I share this folder so I can transfer files to it over the network?
set up an auto mount entry in /etc/fstab for your hdd
in order to facilitate the mount, you could consider ensuring that the hdd filesystem has a proper label.
Now you can export the mount point as a named share under smb.
HTH
Derek
