I’ve downloaded OSMC 2021.08 to setup a Raspberry Pi 4. I’ve already have a DVB-T/T2 device plugged through USB*.
I have OSMC working with Kodi 19 and everything it can get from Internet but:
What steps should I need to do to setup terrestrial TV channels?
(*) Note: I’ve successfully tested this TV dongle with Kaffeine in Raspbian 10 (buster).
I perhaps didn’t explain well:
I already have a Raspberry Pi 4 with OSMC 2021.08 running. And a TV tuner attached via USB (with a working TV antenna). And all this hardware I’ve already checked it’s fully compatible.
Is there a path to install and setup TVHeadend server&client when using OSMC interface?
Okay, I see now grahamh was linking a guide instead of writing me a reply.
I’ve enabled TVHeadend server and I see that I need another computer to access service with a web browser.
Followed setup wizard, TV tuner is detected (the OSMC store dongle), but no channel is found. And after this I don’t find anywhere to trigger a new channels scan.
EDIT:
Oh, I see now that at step “Assign predefined muxes to networks” you MUST select some predefined mux profile. It can’t be left empty. If no profile matches your region, do select: –Generic–: auto-Default
