I am curious if there is a way (even doing some electronic hack) to add power on/off button to OSMC.
I found this article:
but I do not know if it is reliable?
My main problem Is that I usually shutdown Kodi from web UI. But Raspberry led is still on after shutdown. Then I disconnect the cable. Sometime happen that I reconnect the cable, led red turn on but Raspberry does not startup, so I have to disconnect/reconnect cable several time.
I have Raspberry connected to power and HDD connected to Raspberry USB (I have max_current=1 to support this connection).
Just leave it on man…It doesnt consume a lot of power. Set up a screensaver on it and just leave it on. I wouldnt play with the GPIOs…especially if you are planning to do this on/off all the time (+2 times every day).
If the red led is bothering you, there is a way to turn it off by editing the config.txt. I’ve done it with mine, and now only when the pi is doing something i got the yellow led on, otherwise it is completly dark.
I used a momentary button and this video - YouTube to setup the “On” button for my Pi 3. It’s as simple as connecting to the shown GPIO pins, then wiring or soldering to the button. If you have a breadboard I’d try it out first, then go for a permanent setup if you like it. Just make sure you use the shut-down option from the power menu first, after the green LED stops press the button, it’ll start right up.
I cut an extension cable in the middle. Screwed one end on the left side, one on the right thus making a wifi extension cable. You can turn it on/off from your phone and it even has timer settings if you want.
