Hello!
Since my Vero 1 is collecting a bit of dust, I thought I’d try some streaming stuff with it. Is it still possible to upgrade the device to Kodi 18 Leia? Has anyone done so and tried the Netflix or Amazon Prime Add-Ons?
Thank you!
Hello!
Thank you!
Unfortunately v17.6 is the last supported version for this device.
Ah, so there’s no v18 test build “left”?
A v18 test build was never created for Vero 1.
ok, bummer but thanks!
