How to use OSMC Remote on Windows 7 and Kodi?
But as of now, there is no way to change the behavior of the device similar to how a Flirc works where we can load a different config file?
No – you’d need another tool to remap the values of the keypresses.
Any update ?
The new remote works out of the box on Windows.
The older remote requires some remapping.
Can you confirm which remote you have and the problem you are experiencing?
I am using older remote, the problem i have is (option key) & (info key ) are not recognized at all
I’m using windows 10
