Hello!
How can I finish setup screen ? Indeed, this is a weird menu.
Hello!
Select “Finish”, if I recall! I was confused as well.
Yup, press left, select finish.
Thank you! But except checkbox, I cannot click on Finish.
I will wait the next release with a different setup screen.
After 24h stucked on that screen, I am back to 2014 Raspbmc release.
You said “click”. Are you navigating with a mouse? I found that very awkward, and had problems similar to what you are describing. Practise using the keyboard (wireless or USB) and note the peculiar moves made by the up/down arrows. You are almost “there” and dont need to reinstall or revert to older systems.
