Im running OSMC on a RP3.
To help with buffering issues, I’ve created an “advancedsettings.xml” file at this folder location:
/home/osmc/.kodi/userdata/
… and added the recommended setting for cachemembuffersize,readbufferfactor etc.
But - how do I verify that these settings have actually been read & applied pls?
I can’t seem to see anything in the SYSTEM > SYSTEM INFORMATION menu - apart from available memory which stays at approx. 733MB regardless of how high I set cachemembuffersize.
Hence starting to doubt whether my settings are being applied.
Logs easily and quickly verify this.
OK thanks.
I’m still fairly new to all this.
I think I know how to initiate & start a log - but can you explain how I read the log file that gets created pls.
Enable debugging and check kodi.log
If you need help upload the log
To get a better understanding of the problem you are experiencing we need more information from you. Please see How to submit a useful support request - General - OSMC for advice on how to help us.
Thanks for quick response.
At this point I’m not looking to upload a log (although that may come soon ).
Could you explain how I physically open & read the log I create.
Can this be done in OSMC.
Or do I need to do it via the terminal?
Or do I need to copy the file some how & use my pc to read it.
Sorry - all probably daft questions - but I just don’t know.
Thanks - I’ll take a look tonight.
