I logged in with putty as user osmc pw osmc but i cant go into /home/osmc why cant I?
lol
lol
No clue⌠thatâs rather strange.
you wrote exactly
cd /home/osmc
correct?
login as: osmc
OSMC: Open Source Media Center
osmc@192.168.2.101âs password:
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Tue May 12 12:18:38 2015 from 192.168.2.103
osmc@osmc:~$ cd /home/osmc
osmc@osmc:~$
if i log in as root i can go into /home/osmc but thats not the way it works right?
Lol. You actually are in /home/osmc when you log in!
lol ;D
Another question please what do I type in when i want to uninstall this?
Nothing as uninstalling is very complicated. It will most likely not harm your system if it stays installed.
I just installed everything and the installation seemed to run correct. After the installation i returned to the script and choose reboot. But i cant find retropie in the meny and dont know how to manually create the shortcut. Can you please help me?
Please read the first post!!!
After the retropie setup script installed the stuff, you need to select cancel to let my script take over again and install the rest of the stuff and the shortcut.
Please run my script again and choose cancel in the retropie-setup script.
Quick Question - is this compatible with USB installed OSMC?
Thanx! Works prefectly now! Might be the wrong thread, but are there any way to use a usb-connected ps3-controller?
Donât know why it shouldnât. But as this is experimental anyway, feel free to try and report your results
This question came up earlier already but I donât know. As I donât have a ps3/4 controller I cannot test it.
ok, i see. What controller do you use? Or anyone else for that matter. Wouldnt mind buying a new one, this is awesome!
I use snes and nes as well as dualshock lookalike usb controllers. All of them work perfectly for their respective systems after remapping.
Made it work, thanks! Everything now works, except for n64 wich have big graphics problems.
Read a bit about it on the retropie forums. There are multiple versions of the graphics plugins. You can configure them on a per game basis by pressing x while the emulator starts up.
Try some of the available emulators to find the best one for your game.
Edit: If you solved how to use a ps3 controller, let us know how.
Thank you! Pressing X when starting the game solved it! I just chose another emulator.
i followed this when i installed the ps3 controller:
this is for usb-connected ps3 controller, not bluetooth.
@mcobit, Retropie installation works fine, but emulators seems to have misconfiguration because I have tried Neogeo and SNES and no run. Emulationstation donât show any error. The same emulators works fine in Retropie installed from Raspbian.
