a lot of variables when streaming content like router etc.
hard to say why your gear is acting the way it is but i recommend trying different things too see if the end result gets better.
Ok. I think i have made a little progress here.
I tried the android client app (moonlight for android https://play.google.com/store/apps/details?id=com.limelight&hl=el) in my samsung s3 device. I wanted to test it out in order to eliminate some things.
In the beggining i had same issues with my rasp1 (a little video “choppiness” when the screen was rolling - i tested NBA 2K14 game, same game for both rasp and android clients).
I tried to minimize this with lowering the target bitrate (i set it to 3 instead of 10). So my question is: is there any option in moonlight embedded to lower the target bitrate?? I now use the command (to launch moonlight):
moonlight stream -mapping xbox.map 192.168.1.109
(in raspbian image of course but it will be identical i suppose)
by defining it in a config file ![]()
Or
moonlight stream 192.168.1.109 -mapping xbox.map -bitrate 3000
What is the default bitrate? Would i gain better fps if i lower my bitrate?
as i said before try no idea since im not on your setup.
Well i did lowered the bitrate to 3000. Although picture quality deteriorated a lot, not much of a gain in terms of NBA2K14 “smoothness” (it is somehow better but not perfect). So i guess it may be a matter of my host pc/gfe/network/moonlight app (or maybe just rasp1 has not enough power(?) for the decoding procedure).
I tend to think that my server pc needs more cpu power though (as i tried TocaRace 3 in full hd and played perfect in 3000 bitrate)
I followed the guide and i get:
osmc@osmc:~$ sudo apt-get install moonlight-osmc
Reading package lists… Done
Building dependency tree
moonlight-osmc : Depends: moonlight-embedded but it is not installable
E: Unable to correct problems, you have held broken packages.
osmc@osmc:~$
Any thoughts?
You probably don’t have irtimmers repo in your sources.list. If you’ve manually installed moonlight-embedded the script in its current state doesn’t check for that.
I will be pushing the new version to github later today (I just have to verify it installs as it should). This version will be a Kodi addon, and so a lot will be different/fixed.
##Whats working:
settings.xml based Kodi configuration page
Steam, Battle.net, Origin
that should cover alot of games ![]()
I just uploaded the first pre-release of the new Kodi add-on to the new repo on github!
https://github.com/dodslaser/script.moonlight-embedded
Edit: I should point out that it is even hackier than the previous versions. I’ve tested it, and it runs fine for me, but expect some crazy bugs/crashes/freezes anyway!
Can you advise specifically what hardware this has been tested and known to work on?
I’m running a RPi Model B (512M). The performance could be better, but it’s definitely enough. A higher memory split (256/256) and moderate overclock helps.
Edit: I’ll probably upgrade to a Pi2 soon.
I am a little confused (again).
I ve finally managed to install moonlight from here
I have also managed to create a shortcut in kodi (with a nice png file) to launch from the GUI. A quick question:
My /etc/moonlight-osmc/moonlight-osmc.conf file is smth like this:
#!/bin/sh
MOONLIGHT_RES='-720'
MOONLIGHT_IP='192.168.1.109'
MOONLIGHT_ARGS='-30fps'
moonlight map xbox.map , and followed the instructions to create it.
Is this still on to-do list?
Just replace the last line with:
MOONLIGHT_ARGS="-30fps -input /path/to/device -map /path/to/map"
Well that doesnt work. I used
MOONLIGHT_ARGS=“-30fps -input /dev/input/event0 -map /home/osmc/xbox.map”
I placed xbox.map (downloaded from here) in /home/osmc/ (i had permission troubles copying to /usr/etc) and used lsinput command to check for my wireless xbox input.
I get an error "…option should be followed by the input to be mapped (i can’t see the first words). My lsinput output is here
Edit: I cjanged it to MOONLIGHT_ARGS=‘-30fps -mapping xbox.map -input /dev/input/event0’ and now i get an error “unable to open custom mapping file: xbox.map”
Any thoughts?
Ah, I forgot the order matters. What is your output of ls -l /home/osmc/xbox.map?
You could always try mapping the input yourself.
Edit: Oh and the version you’re using is not being developed anymore. I’m replacing it with a Kodi add-on
Well my ls command is this
osmc@osmc:~$ ls -l /home/osmc/xbox.map
-rwxr-xr-x 1 osmc osmc 498 Oct 25 12:00 /home/osmc/xbox.map
I have also attached a wired gamepad (logitech) and used lsinput to show me the info. I then used jstest /dev/input/js0 to test it, but while i can see this:
osmc@osmc:~$ jstest /dev/input/js0
Driver version is 2.1.0.
Joystick (Logitech RymblePad 2 pad) has 8 axes (X, Y, Z, Rx, Ry, Rz, Hat0X, Hat0Y)
and 11 buttons (BtnX, BtnY, BtnTL, BtnTR, BtnTR2, BtnSelect, BtnThumbL, BtnThumbR, ?, ?, ?).
Testing … (interrupt to exit)
Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: 0 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: 0 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: -1 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: -1 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: -1 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off Axes: 0: 0 1: -1 2: 0 3: 0 4: -1 5: 0 6: 0 7: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off 8:off 9:off 10:off
when i move buttons and sticks nothing works! Any ideas?
Edit: I will try this for my xbox controller and will keep my fingers crossed…
Edit:
Well i ve followed this guide and managed to use my xbox controller with moonlight embedded (didnt use the kodi-add-on). It works as expected and thanks for this nice how to!
About kodi-addon: Nice RGUI and very nice try really. Of course there are problems too. One major one is in having any of my controllers to work. This is my add-on settings. I always get a “input device not mapped” even though there is an xbox controller in /dev/input/eventX found in lsinput command. My keyboard/mouse inputs are working as expected. So for now - i leave it aside ![]()
Now - the only think that remains - is how to use my second/3rd wired controller with moonlight embedded! If anyone knows please share it with us!![]()
Try with sudo
