Been playing back some recordings made with TvHeadend on my Vero4k+ and pretty consistently experiencing an issue where approximately 30 minutes into watching the recording I get a banner pop up indicating “HTSP client has lost connection” and the playback of the recording stops.
The recordings are stored on my NAS mounted in the Vero using autofs. I play DVDs and Blu-rays from the same NAS with no issues. The TvHeadend server runs on the same Vero4k I am playing back from and I have configured the client to use a localhost IP (127.0.0.1)
Yep, happy to give that a go. Just to clarify, do you mean the internal storage of the Vero? Or a USB or HDD connected to the Vero? If the latter, then I might struggle as I don’t have a hub and all the USB ports are taken.
Based on what I can see, they don’t seem to help much either. Just saying disconnected and then almost immediately reconnected
But maybe you can see something I can’t…
EDIT:
I just had a thought, the logs I grabbed above are just a subset of the larger set I grabbed before. Is that correct?
If so, is there another way to get the separate tvheadend logs?
Checked out the TvHeadend docs and you were right, there was the ability to enable TvHeadend debug logs and add them to the system logs. Just needed to enable “Debug to syslog” and “Debug trace (low level)” and specify what subsystems I wanted logging for as below:
I’ve had another look at the logs.
Unfortunately I can’t see any obvious reason. The TVHeadend forums have some reports of this, but there doesn’t seem to be a general solution.
When recorded the file to the local storage, did you try to directly play the mkv file using the kodi? (I assume it’s an mkv since I saw the tvheadend profile name ‘MKV_local’ in your logs)
Is the file incomplete?
Just tried that this morning and the recording seems to play fine with no issues whatsoever… Also on a side note I tried playing it with my TVHeadend iPad client app and also seemed to have no issues…
I’ve been meaning to follow through this HowTo and try to get it setup. Maybe this is my best solution going forward.
If it’s not too much hassle – is it possible for you to set up a mount so you can play the recordings directly from the NAS and not via TVH for a few days and let us know how you get on?
Please keep in mind this setup will rename and move your recorded files. Afterwards they won’t be available for streaming in TVH anymore, but instead will show up as the correct movies and shows in Kodi.
