Just bought a hue kit.
Installed the addon…
Everything works.
However when i enable the addon, i get stutters.
As soon as i disable the hue addon, stutter is gone…
Any help?
Everything works.
Any help?
So, in summary:
Log Uploader
method within the My OSMC menu in the GUI or the ssh
method invoking command grab-logs -A
Also which Addon are you using?
Anyone?
I would ask the developer of the plugin for support, can’t see anything unusually in the log.
Thanks Tom.
Lol as soon as i started the topic, i knew that would end with, ask the app developer.
I will.so you cant see anything in logs… Damn cause its there.
And why do you think that we should support the Hue addon instead of its developer?
