hi guys can anybody solve my problem my hyperion leds wont shutdown when I power down osmc they just stay on also Ive read somewhere that you could possibly use the tv remote to turn on/off lights could somebody help on this matter thanks
There is a thread describing how to use keys on the remote to turn hyperion on/off. Just search.
The leds staying on is normal behaviour as they only receive a command and stay in the same state until another command is issued or power is cut.
You basically need a script that sets all leds to 0 brightness and map it to a remotecontrolbutton.
Edit: Here is the guide describing remote setup. Simply searching the forum for “hyperion remote” would have done the job.
@mcobit thanks for your reply mate I have searched but have found nothing so I thought id ask thanks anyway
See my edit.
