Hi everyone !
I’m using a lightberry since 1 year with osmc on my raspberry Pi 3 without any problems !
Since i updated OSMC with the march 2018 update i have a strange problem :
Hyperion start on boot and works perfectly. After a few minutes ( it depends, sometimes it’s more ou less than 15 minutes), my leds freeze (the colours stayed the same and doesn’t change anymore) and then, the leds stop working.
I am obliged to relaunch the service manually, and the same thing happened again and again.
Things i’ve already tried :
- reinstall hyperion
- check my hyperion.config.json file (i pasted it below)
the problem still remains …
Please help me,
Thanks !
Here is my hyperion.config.json file :
// Automatically generated configuration file for Hyperion ambilight daemon
// Notice: All values are explained with comments at our wiki: wiki.hyperion-project.org (config area)
// Generated by: HyperCon (The Hyperion deamon configuration file builder)
// Created with HyperCon V1.03.3 (22.10.2017)
// DEVICE CONFIGURATION
“device” :
“name” : “MyHyperionConfig”,
“type” : “AdalightApa102”,
“output” : “/dev/ttyACM0”,
“rate” : 100000,
“delayAfterConnect” : 0,
“colorOrder” : “bgr”
// COLOR CALIBRATION CONFIG
"color" :
"channelAdjustment" :
"id" : "default",
"leds" : "*",
"pureRed" :
"redChannel" : 255,
"greenChannel" : 0,
"blueChannel" : 0
"pureGreen" :
"redChannel" : 0,
"greenChannel" : 153,
"blueChannel" : 0
"pureBlue" :
"redChannel" : 0,
"greenChannel" : 0,
"blueChannel" : 77
"temperature" :
"id" : "default",
"leds" : "*",
"correctionValues" :
"red" : 161,
"green" : 185,
"blue" : 255
"transform" :
"id" : "default",
"leds" : "*",
"hsl" :
"saturationGain" : 1.0000,
"luminanceGain" : 1.0000,
"luminanceMinimum" : 0.0000
"red" :
"threshold" : 0.0000,
"gamma" : 2.5000
"green" :
"gamma" : 2.5000
"blue" :
"gamma" : 2.5000
// SMOOTHING CONFIG
"smoothing" :
"type" : "linear",
"time_ms" : 100,
"updateFrequency" : 40.0000,
"updateDelay" : 0
// V4L2 GRABBER CONFIG
"grabber-v4l2" :
"device" : "/dev/video0",
"input" : 0,
"standard" : "PAL",
"width" : -1,
"height" : -1,
"frameDecimation" : 2,
"sizeDecimation" : 8,
"priority" : 900,
"mode" : "2D",
"cropLeft" : 45,
"cropRight" : 41,
"cropTop" : 20,
"cropBottom" : 37,
"redSignalThreshold" : 0.0,
"greenSignalThreshold" : 0.0,
"blueSignalThreshold" : 0.0
// BLACKBORDER CONFIG
"blackborderdetector" :
"enable" : true,
"threshold" : 0.04,
"unknownFrameCnt" : 600,
"borderFrameCnt" : 50,
"maxInconsistentCnt" : 10,
"blurRemoveCnt" : 1,
"mode" : "default"
// BOOTEFFECT CONFIG
"bootsequence" :
"color" : [0,0,0],
"effect" : "Rainbow swirl fast",
"duration_ms" : 3000,
"priority" : 700
// JSON SERVER CONFIG
"jsonServer" :
"port" : 19444
// PROTO SERVER CONFIG
"protoServer" :
"port" : 19445
// EFFECT PATH
"effects" :
"paths" :
"/storage/hyperion/effects",
"/usr/share/hyperion/effects"
// NO FRAME GRABBER CONFIG
// NO KODI CHECK CONFIG
// NO BOBLIGHT SERVER CONFIG
// NO JSON/PROTO FORWARD CONFIG
// LED CONFIGURATION
"leds" :
"index" : 0,
"hscan" : { "minimum" : 0.9500, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.9200, "maximum" : 1.0000 }
"index" : 1,
"vscan" : { "minimum" : 0.9083, "maximum" : 1.0000 }
"index" : 2,
"vscan" : { "minimum" : 0.8250, "maximum" : 0.9250 }
"index" : 3,
"vscan" : { "minimum" : 0.7417, "maximum" : 0.8417 }
"index" : 4,
"vscan" : { "minimum" : 0.6583, "maximum" : 0.7583 }
"index" : 5,
"vscan" : { "minimum" : 0.5750, "maximum" : 0.6750 }
"index" : 6,
"vscan" : { "minimum" : 0.4917, "maximum" : 0.5917 }
"index" : 7,
"vscan" : { "minimum" : 0.4083, "maximum" : 0.5083 }
"index" : 8,
"vscan" : { "minimum" : 0.3250, "maximum" : 0.4250 }
"index" : 9,
"vscan" : { "minimum" : 0.2417, "maximum" : 0.3417 }
"index" : 10,
"vscan" : { "minimum" : 0.1583, "maximum" : 0.2583 }
"index" : 11,
"vscan" : { "minimum" : 0.0750, "maximum" : 0.1750 }
"index" : 12,
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0917 }
"index" : 13,
"hscan" : { "minimum" : 0.9542, "maximum" : 1.0000 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0800 }
"index" : 14,
"hscan" : { "minimum" : 0.9125, "maximum" : 0.9625 },
"index" : 15,
"hscan" : { "minimum" : 0.8708, "maximum" : 0.9208 },
"index" : 16,
"hscan" : { "minimum" : 0.8292, "maximum" : 0.8792 },
"index" : 17,
"hscan" : { "minimum" : 0.7875, "maximum" : 0.8375 },
"index" : 18,
"hscan" : { "minimum" : 0.7458, "maximum" : 0.7958 },
"index" : 19,
"hscan" : { "minimum" : 0.7042, "maximum" : 0.7542 },
"index" : 20,
"hscan" : { "minimum" : 0.6625, "maximum" : 0.7125 },
"index" : 21,
"hscan" : { "minimum" : 0.6208, "maximum" : 0.6708 },
"index" : 22,
"hscan" : { "minimum" : 0.5792, "maximum" : 0.6292 },
"index" : 23,
"hscan" : { "minimum" : 0.5375, "maximum" : 0.5875 },
"index" : 24,
"hscan" : { "minimum" : 0.4958, "maximum" : 0.5458 },
"index" : 25,
"hscan" : { "minimum" : 0.4542, "maximum" : 0.5042 },
"index" : 26,
"hscan" : { "minimum" : 0.4125, "maximum" : 0.4625 },
"index" : 27,
"hscan" : { "minimum" : 0.3708, "maximum" : 0.4208 },
"index" : 28,
"hscan" : { "minimum" : 0.3292, "maximum" : 0.3792 },
"index" : 29,
"hscan" : { "minimum" : 0.2875, "maximum" : 0.3375 },
"index" : 30,
"hscan" : { "minimum" : 0.2458, "maximum" : 0.2958 },
"index" : 31,
"hscan" : { "minimum" : 0.2042, "maximum" : 0.2542 },
"index" : 32,
"hscan" : { "minimum" : 0.1625, "maximum" : 0.2125 },
"index" : 33,
"hscan" : { "minimum" : 0.1208, "maximum" : 0.1708 },
"index" : 34,
"hscan" : { "minimum" : 0.0792, "maximum" : 0.1292 },
"index" : 35,
"hscan" : { "minimum" : 0.0375, "maximum" : 0.0875 },
"index" : 36,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0458 },
"index" : 37,
"hscan" : { "minimum" : 0.0000, "maximum" : 0.0500 },
"vscan" : { "minimum" : 0.0000, "maximum" : 0.0846 }
"index" : 38,
"vscan" : { "minimum" : 0.0692, "maximum" : 0.1615 }
"index" : 39,
"vscan" : { "minimum" : 0.1462, "maximum" : 0.2385 }
"index" : 40,
"vscan" : { "minimum" : 0.2231, "maximum" : 0.3154 }
"index" : 41,
"vscan" : { "minimum" : 0.3000, "maximum" : 0.3923 }
"index" : 42,
"vscan" : { "minimum" : 0.3769, "maximum" : 0.4692 }
"index" : 43,
"vscan" : { "minimum" : 0.4538, "maximum" : 0.5462 }
"index" : 44,
"vscan" : { "minimum" : 0.5308, "maximum" : 0.6231 }
"index" : 45,
"vscan" : { "minimum" : 0.6077, "maximum" : 0.7000 }
"index" : 46,
"vscan" : { "minimum" : 0.6846, "maximum" : 0.7769 }
"index" : 47,
"vscan" : { "minimum" : 0.7615, "maximum" : 0.8538 }
"index" : 48,
"vscan" : { "minimum" : 0.8385, "maximum" : 0.9308 }
"index" : 49,
"vscan" : { "minimum" : 0.9154, "maximum" : 1.0000 }
"index" : 50,
"index" : 51,
"index" : 52,
"index" : 53,
"index" : 54,
"index" : 55,
"index" : 56,
"index" : 57,
"index" : 58,
"index" : 59,
"index" : 60,
"index" : 61,
"index" : 62,
"index" : 63,
"index" : 64,
"index" : 65,
"index" : 66,
"index" : 67,
"index" : 68,
"index" : 69,
"index" : 70,
"index" : 71,
"index" : 72,
"index" : 73,
"endOfJson" : "endOfJson"
