hello people
Before I was using raspbmc, no problem, I’ll try to explain my problem.
Use the OSMC, together with the transmission and HD to store my movies.
It happens that I am unable to view my folders on the network and also by OSMC file manager can not delete or rename my folders.
below I will put the tutorial to follow for installation of transmission and permissionamento folders.
only way to get to getting to delete my films is the torrent manager which exclude the torrent and along the main file.
please help me.
I have a friend with the installed rc2 not you any of these problems, can this be?
sudo mkdir /media/hdd
sudo mount -t auto /dev/sda1 /media/hdd
sudo nano /etc/fstab
/dev/sda1 /media/hdd auto noatime 0 0
sudo apt-get install transmission-daemon
sudo mkdir /media/hdd/incomplete
sudo mkdir /media/hdd/complete
sudo mkdir /media/hdd/filmes
sudo mkdir /media/hdd/series
sudo usermod -a -G debian-transmission debian-transmission
sudo chgrp debian-transmission /media/hdd/incomplete
sudo chgrp debian-transmission /media/hdd/complete
sudo chgrp debian-transmission /media/hdd/filmes
sudo chgrp debian-transmission /media/hdd/series
Sudo chmod 777 /media/hdd/incomplete
Sudo chmod 777 /media/hdd/complete
Sudo chmod 777 /media/hdd/filmes
Sudo chmod 777 /media/hdd/series
sudo service transmission-daemon stop
sudo adduser debian-transmission debian-transmission
sudo chown debian-transmission -R /var/lib/transmission-daemon/info/
sudo chown debian-transmission -R /media/hdd/complete
sudo chown debian-transmission -R /media/hdd/incomplete
sudo chown debian-transmission -R /media/hdd/filmes
sudo chown debian-transmission -R /media/hdd/series
sudo service transmission-daemon start
sudo cp /etc/transmission-daemon/settings.json /etc/transmission-daemon/settings.json.old
sudo nano /etc/transmission-daemon/settings.json
alt-speed-down: 50,
alt-speed-enabled: false,
alt-speed-time-begin: 540,
alt-speed-time-day: 127,
alt-speed-time-enabled: false,
alt-speed-time-end: 1020,
alt-speed-up: 50,
bind-address-ipv4″: 0.0.0.0″,
bind-address-ipv6″: ::,
blocklist-enabled: false,
blocklist-url: http://www.example.com/blocklist,
cache-size-mb: 4,
dht-enabled: true,
download-dir: /media/hdd/complete, (Aqui apontamos a pasta de downloads completos)
download-limit: 100,
download-limit-enabled: 0,
download-queue-enabled: true,
download-queue-size: 5,
encryption: 1,
idle-seeding-limit: 30,
idle-seeding-limit-enabled: false,
incomplete-dir: /media/hdd/incomplete, (Aqui apontamos a pasta de downloads incompletos ou em progresso)
incomplete-dir-enabled: true, (Habilita a pasta de downloads completos ou em progresso)
lpd-enabled: false,
max-peers-global: 200,
message-level: 2,
peer-congestion-algorithm: ,
peer-limit-global: 240,
peer-limit-per-torrent: 60,
peer-port: 51413,
peer-port-random-high: 65535,
peer-port-random-low: 49152,
peer-port-random-on-start: false,
peer-socket-tos: default,
pex-enabled: true,
port-forwarding-enabled: false,
preallocation: 1,
prefetch-enabled: 1,
queue-stalled-enabled: true,
queue-stalled-minutes: 30,
ratio-limit: 2,
ratio-limit-enabled: false,
rename-partial-files: true,
rpc-authentication-required: true,
rpc-bind-address: 0.0.0.0″,
rpc-enabled: true,
rpc-password: (redacted), (Ao fechar o arquivo ele criptografa a senha!)
rpc-port: 9091, (Tente manter o padrão mas se quiser alterar, fique a vontade)
rpc-url: /transmission/,
rpc-username: transmission, (usuário de acesso ao Transmission)
rpc-whitelist: 127.0.0.1″,
rpc-whitelist-enabled: false, (Desabilita a Whistelist que é uma lista de ip’s permitidos)
scrape-paused-torrents-enabled: true,
script-torrent-done-enabled: false,
script-torrent-done-filename: ,
seed-queue-enabled: false,
seed-queue-size: 10,
speed-limit-down: 100,
speed-limit-down-enabled: false,
speed-limit-up: 100,
speed-limit-up-enabled: false,
start-added-torrents: true,
trash-original-torrent-files: false,
umask: 18,
upload-limit: 100,
upload-limit-enabled: 0,
upload-slots-per-torrent: 14,
utp-enabled: true
sudo service transmission-daemon reload
sudo service transmission-daemon restart
