This is the kodi log (debug mode) from the time I entered the youtube search until it was restarted. I don’t see anything relevant.
2019-04-23 17:45:29.356 T:1915762224 DEBUG: ------ Window Deinit (DialogFavourites.xml) ------
2019-04-23 17:45:29.357 T:1915762224 DEBUG: FreeVisualisation() done
2019-04-23 17:45:29.422 T:1345008352 DEBUG: Thread waiting start, auto delete: false
2019-04-23 17:45:29.426 T:1345008352 DEBUG: Thread waiting 1345008352 terminating
2019-04-23 17:45:29.427 T:1915762224 DEBUG: ------ Window Init (MyVideoNav.xml) ------
2019-04-23 17:45:29.428 T:1915762224 DEBUG: [Warning] CGUITextureManager::GetTexturePath: could not find texture ‘noop’
2019-04-23 17:45:29.447 T:1915762224 ERROR: Control 50 in window 10025 has been asked to focus, but it can’t
2019-04-23 17:45:29.487 T:1915762224 DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.youtube/kodion/search/input/)
2019-04-23 17:45:29.487 T:1915762224 DEBUG: ParentPath = [plugin://plugin.video.youtube/kodion/search/input/]
2019-04-23 17:45:29.488 T:1345008352 DEBUG: Thread waiting start, auto delete: false
2019-04-23 17:45:29.504 T:1386971872 DEBUG: CAddonDatabase::SetLastUsed[plugin.video.youtube] took 17 ms
2019-04-23 17:45:29.505 T:1345008352 DEBUG: StartScript - calling plugin YouTube(‘plugin://plugin.video.youtube/kodion/search/input/’,‘8’,‘’,‘resume:false’)
2019-04-23 17:45:29.507 T:1370186464 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-04-23 17:45:29.507 T:1370186464 INFO: initializing python engine.
2019-04-23 17:45:29.507 T:1370186464 DEBUG: CPythonInvoker(57, /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py): start processing
2019-04-23 17:45:29.588 T:1915762224 DEBUG: ------ Window Init (DialogBusy.xml) ------
2019-04-23 17:45:30.010 T:1370186464 DEBUG: -->Python Interpreter Initialized<–
2019-04-23 17:45:30.010 T:1370186464 DEBUG: CPythonInvoker(57, /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py): the source file to load is “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py”
2019-04-23 17:45:30.012 T:1370186464 DEBUG: CPythonInvoker(57, /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py): setting the Python path to /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib:/home/osmc/.kodi/addons/script.module.certifi/lib:/home/osmc/.kodi/addons/script.module.chardet/lib:/home/osmc/.kodi/addons/script.module.idna/lib:/home/osmc/.kodi/addons/script.module.requests/lib:/home/osmc/.kodi/addons/script.module.six/lib:/home/osmc/.kodi/addons/script.module.urllib3/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2019-04-23 17:45:30.012 T:1370186464 DEBUG: CPythonInvoker(57, /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py): entering source directory /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib
2019-04-23 17:45:30.012 T:1370186464 DEBUG: CPythonInvoker(57, /home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py): instantiating addon using automatically obtained id of “plugin.video.youtube” dependent on version 2.20.0 of the xbmc.python api
2019-04-23 17:45:33.402 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.402 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.416 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:33.428 T:1370186464 DEBUG: [plugin.video.youtube] send_notification: |check_settings| → |{“httpd_address”: “0.0.0.0”, “use_httpd”: false, “whitelist”: “”, “httpd_port”: 50152}|
2019-04-23 17:45:33.433 T:1370186464 DEBUG: [plugin.video.youtube] JSONStore Load |/home/osmc/.kodi/userdata/addon_data/plugin.video.youtube/api_keys.json|
2019-04-23 17:45:33.443 T:1370186464 DEBUG: [plugin.video.youtube] JSONStore Load |/home/osmc/.kodi/userdata/addon_data/plugin.video.youtube/access_manager.json|
2019-04-23 17:45:33.457 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.457 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.458 T:1915749088 DEBUG: CAnnouncementManager - Announcement: check_settings from plugin.video.youtube
2019-04-23 17:45:33.458 T:1915749088 DEBUG: GOT ANNOUNCEMENT, type: 512, from plugin.video.youtube, message check_settings
2019-04-23 17:45:33.469 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:33.489 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.489 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.499 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:33.517 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.517 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.527 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:33.531 T:1658049248 DEBUG: Skin Helper Service → Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: [“%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D”]
2019-04-23 17:45:33.532 T:1649656544 DEBUG: Skin Helper Widgets → Kodi_Monitor: sender plugin.video.youtube - method: Other.check_settings - data: [“%7B%22httpd_address%22%3A%20%220.0.0.0%22%2C%20%22use_httpd%22%3A%20false%2C%20%22whitelist%22%3A%20%22%22%2C%20%22httpd_port%22%3A%2050152%7D”]
2019-04-23 17:45:33.546 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.546 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.556 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:33.564 T:1370186464 DEBUG: CSettingsManager: requested setting (kodion.access_token) was not found.
2019-04-23 17:45:33.564 T:1370186464 DEBUG: CSettingsManager: requested setting (kodion.refresh_token) was not found.
2019-04-23 17:45:33.564 T:1370186464 DEBUG: CSettingsManager: requested setting (kodion.access_token.expires) was not found.
2019-04-23 17:45:33.565 T:1370186464 DEBUG: CSettingsManager: requested setting (youtube.api.last.hash) was not found.
2019-04-23 17:45:33.567 T:1370186464 DEBUG: [plugin.video.youtube] User: |0| Using API key set: |1|
2019-04-23 17:45:33.743 T:1674834656 DEBUG: [plugin.video.youtube] onNotification: |check_settings| → |{“httpd_address”: “0.0.0.0”, “use_httpd”: false, “whitelist”: “”, “httpd_port”: 50152}|
2019-04-23 17:45:33.744 T:1370186464 DEBUG: [plugin.video.youtube] Starting Kodion framework by bromix…
2019-04-23 17:45:33.880 T:1370186464 NOTICE: [plugin.video.youtube] Running: YouTube (6.4.1) on Leia (Kodi-18.2) with Python 2.7.13
Path: /kodion/search/input/
Params: {}
2019-04-23 17:45:33.884 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting definitions
2019-04-23 17:45:33.884 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: trying to load setting definitions from old format…
2019-04-23 17:45:33.894 T:1370186464 DEBUG: CAddonSettings[plugin.video.youtube]: loading setting values
2019-04-23 17:45:34.023 T:1915762224 DEBUG: ------ Window Init (DialogKeyboard.xml) ------
2019-04-23 17:45:34.033 T:1915749088 DEBUG: CAnnouncementManager - Announcement: OnInputRequested from xbmc
2019-04-23 17:45:34.033 T:1915749088 DEBUG: GOT ANNOUNCEMENT, type: 128, from xbmc, message OnInputRequested
2019-04-23 17:45:34.073 T:1649656544 DEBUG: Skin Helper Widgets → Kodi_Monitor: sender xbmc - method: Input.OnInputRequested - data: {“title”:“Search”,“type”:“keyboard”,“value”:“”}
2019-04-23 17:45:34.118 T:1658049248 DEBUG: Skin Helper Service → Kodi_Monitor: sender xbmc - method: Input.OnInputRequested - data: {“title”:“Search”,“type”:“keyboard”,“value”:“”}
2019-04-23 17:45:35.706 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:35.707 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:35.736 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
2019-04-23 17:45:35.977 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 270 (rep:0 size:0)
2019-04-23 17:45:35.977 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:36.371 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:36.372 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:36.420 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, trying keyboard action 3
2019-04-23 17:45:36.567 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 196 (rep:0 size:0)
2019-04-23 17:45:36.567 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:37.067 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:37.067 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:37.086 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
2019-04-23 17:45:37.257 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 190 (rep:0 size:0)
2019-04-23 17:45:37.257 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:37.616 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:37.617 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:37.620 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
2019-04-23 17:45:37.787 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 171 (rep:0 size:0)
2019-04-23 17:45:37.787 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:38.841 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
2019-04-23 17:45:38.842 T:1742717664 DEBUG: PushCecKeypress - added key a9
2019-04-23 17:45:38.870 T:1915762224 DEBUG: HandleKey: 169 (0xa9, obc86) pressed, action is Left
2019-04-23 17:45:39.147 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 306 (rep:0 size:0)
2019-04-23 17:45:39.147 T:1742717664 DEBUG: PushCecKeypress - ignored key a9
2019-04-23 17:45:39.316 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
2019-04-23 17:45:39.317 T:1742717664 DEBUG: PushCecKeypress - added key a9
2019-04-23 17:45:39.353 T:1915762224 DEBUG: HandleKey: 169 (0xa9, obc86) pressed, action is Left
2019-04-23 17:45:39.622 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 305 (rep:0 size:0)
2019-04-23 17:45:39.622 T:1742717664 DEBUG: PushCecKeypress - ignored key a9
2019-04-23 17:45:40.996 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
2019-04-23 17:45:40.996 T:1742717664 DEBUG: PushCecKeypress - added key a9
2019-04-23 17:45:41.036 T:1915762224 DEBUG: HandleKey: 169 (0xa9, obc86) pressed, action is Left
2019-04-23 17:45:41.253 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 257 (rep:0 size:0)
2019-04-23 17:45:41.253 T:1742717664 DEBUG: PushCecKeypress - ignored key a9
2019-04-23 17:45:41.401 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 0 (rep:0 size:0)
2019-04-23 17:45:41.401 T:1742717664 DEBUG: PushCecKeypress - added key a9
2019-04-23 17:45:41.420 T:1915762224 DEBUG: HandleKey: 169 (0xa9, obc86) pressed, action is Left
2019-04-23 17:45:41.592 T:1742717664 DEBUG: PushCecKeypress - received key a9 duration 191 (rep:0 size:0)
2019-04-23 17:45:41.592 T:1742717664 DEBUG: PushCecKeypress - ignored key a9
2019-04-23 17:45:42.311 T:1742717664 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
2019-04-23 17:45:42.311 T:1742717664 DEBUG: PushCecKeypress - added key b
2019-04-23 17:45:42.336 T:1915762224 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-04-23 17:45:42.347 T:1915762224 DEBUG: CDirectoryProvider[plugin://plugin.program.autocompletion?info=autocomplete&&id=h&&limit=12]: refreshing…
2019-04-23 17:45:42.350 T:1464857312 DEBUG: StartScript - calling plugin AutoCompletion for virtual keyboard(‘plugin://plugin.program.autocompletion/’,‘9’,‘?info=autocomplete&&id=h&&limit=12’,‘resume:false’)
2019-04-23 17:45:42.350 T:1403757280 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-04-23 17:45:42.351 T:1403757280 INFO: initializing python engine.
2019-04-23 17:45:42.351 T:1403757280 DEBUG: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): start processing
2019-04-23 17:45:42.597 T:1742717664 DEBUG: PushCecKeypress - received key b duration 286 (rep:0 size:0)
2019-04-23 17:45:42.597 T:1742717664 DEBUG: PushCecKeypress - ignored key b
2019-04-23 17:45:42.867 T:1403757280 DEBUG: -->Python Interpreter Initialized<–
2019-04-23 17:45:42.867 T:1403757280 DEBUG: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): the source file to load is “/home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py”
2019-04-23 17:45:42.868 T:1403757280 DEBUG: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): setting the Python path to /home/osmc/.kodi/addons/plugin.program.autocompletion:/home/osmc/.kodi/addons/script.module.autocompletion/lib:/home/osmc/.kodi/addons/script.module.simplejson/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2019-04-23 17:45:42.869 T:1403757280 DEBUG: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): entering source directory /home/osmc/.kodi/addons/plugin.program.autocompletion
2019-04-23 17:45:42.869 T:1403757280 DEBUG: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): instantiating addon using automatically obtained id of “plugin.program.autocompletion” dependent on version 2.24.0 of the xbmc.python api
2019-04-23 17:45:43.541 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 0 (rep:0 size:0)
2019-04-23 17:45:43.541 T:1742717664 DEBUG: PushCecKeypress - added key a8
2019-04-23 17:45:43.553 T:1915762224 DEBUG: HandleKey: 168 (0xa8, obc87) pressed, action is Right
2019-04-23 17:45:43.727 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 186 (rep:0 size:0)
2019-04-23 17:45:43.727 T:1742717664 DEBUG: PushCecKeypress - ignored key a8
2019-04-23 17:45:44.001 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 0 (rep:0 size:0)
2019-04-23 17:45:44.001 T:1742717664 DEBUG: PushCecKeypress - added key a8
2019-04-23 17:45:44.036 T:1915762224 DEBUG: HandleKey: 168 (0xa8, obc87) pressed, action is Right
2019-04-23 17:45:44.177 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 176 (rep:0 size:0)
2019-04-23 17:45:44.177 T:1742717664 DEBUG: PushCecKeypress - ignored key a8
2019-04-23 17:45:44.327 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 0 (rep:0 size:0)
2019-04-23 17:45:44.327 T:1742717664 DEBUG: PushCecKeypress - added key a8
2019-04-23 17:45:44.336 T:1915762224 DEBUG: HandleKey: 168 (0xa8, obc87) pressed, action is Right
2019-04-23 17:45:44.397 T:1403757280 DEBUG: version 1.0.1 started
2019-04-23 17:45:44.437 T:1403757280 DEBUG: CAddonSettings[plugin.program.autocompletion]: loading setting definitions
2019-04-23 17:45:44.437 T:1403757280 DEBUG: CAddonSettings[plugin.program.autocompletion]: trying to load setting definitions from old format…
2019-04-23 17:45:44.440 T:1403757280 DEBUG: plugin.program.autocompletion: opened textfile /home/osmc/.kodi/userdata/addon_data/plugin.program.autocompletion/Google/b76c860c855f3fa3041bb6193a5fadce.txt.
2019-04-23 17:45:44.445 T:1403757280 DEBUG: plugin.program.autocompletion: loaded file for http://clients1.google.com/complete/search?hl=en&q=h&json=t&client=serp&ds=yt. time: 0.006342
2019-04-23 17:45:44.453 T:1742717664 DEBUG: PushCecKeypress - received key a8 duration 126 (rep:0 size:0)
2019-04-23 17:45:44.453 T:1742717664 DEBUG: PushCecKeypress - ignored key a8
2019-04-23 17:45:44.522 T:1403757280 DEBUG: finished
2019-04-23 17:45:44.522 T:1403757280 INFO: CPythonInvoker(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): script successfully run
2019-04-23 17:45:44.522 T:1403757280 DEBUG: onExecutionDone(58, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py)
2019-04-23 17:45:44.870 T:1403757280 INFO: Python interpreter stopped
2019-04-23 17:45:44.871 T:1403757280 DEBUG: Thread LanguageInvoker 1403757280 terminating
2019-04-23 17:45:45.236 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:45.236 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:45.270 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
2019-04-23 17:45:45.427 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 191 (rep:0 size:0)
2019-04-23 17:45:45.427 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:46.251 T:1742717664 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
2019-04-23 17:45:46.255 T:1742717664 DEBUG: PushCecKeypress - added key b
2019-04-23 17:45:46.286 T:1915762224 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-04-23 17:45:46.295 T:1915762224 DEBUG: CDirectoryProvider[plugin://plugin.program.autocompletion?info=autocomplete&&id=ho&&limit=12]: refreshing…
2019-04-23 17:45:46.297 T:1464857312 DEBUG: StartScript - calling plugin AutoCompletion for virtual keyboard(‘plugin://plugin.program.autocompletion/’,‘10’,‘?info=autocomplete&&id=ho&&limit=12’,‘resume:false’)
2019-04-23 17:45:46.298 T:1403757280 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-04-23 17:45:46.298 T:1403757280 INFO: initializing python engine.
2019-04-23 17:45:46.298 T:1403757280 DEBUG: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): start processing
2019-04-23 17:45:46.542 T:1742717664 DEBUG: PushCecKeypress - received key b duration 291 (rep:0 size:0)
2019-04-23 17:45:46.542 T:1742717664 DEBUG: PushCecKeypress - ignored key b
2019-04-23 17:45:46.796 T:1403757280 DEBUG: -->Python Interpreter Initialized<–
2019-04-23 17:45:46.797 T:1403757280 DEBUG: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): the source file to load is “/home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py”
2019-04-23 17:45:46.798 T:1403757280 DEBUG: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): setting the Python path to /home/osmc/.kodi/addons/plugin.program.autocompletion:/home/osmc/.kodi/addons/script.module.autocompletion/lib:/home/osmc/.kodi/addons/script.module.simplejson/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2019-04-23 17:45:46.798 T:1403757280 DEBUG: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): entering source directory /home/osmc/.kodi/addons/plugin.program.autocompletion
2019-04-23 17:45:46.798 T:1403757280 DEBUG: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): instantiating addon using automatically obtained id of “plugin.program.autocompletion” dependent on version 2.24.0 of the xbmc.python api
2019-04-23 17:45:47.327 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2019-04-23 17:45:47.327 T:1742717664 DEBUG: PushCecKeypress - added key a7
2019-04-23 17:45:47.354 T:1915762224 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, action is Down
2019-04-23 17:45:47.503 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 176 (rep:0 size:0)
2019-04-23 17:45:47.503 T:1742717664 DEBUG: PushCecKeypress - ignored key a7
2019-04-23 17:45:47.996 T:1742717664 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
2019-04-23 17:45:47.996 T:1742717664 DEBUG: PushCecKeypress - added key b
2019-04-23 17:45:48.003 T:1915762224 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-04-23 17:45:48.012 T:1915762224 DEBUG: CDirectoryProvider[plugin://plugin.program.autocompletion?info=autocomplete&&id=hol&&limit=12]: refreshing…
2019-04-23 17:45:48.014 T:1386971872 DEBUG: StartScript - calling plugin AutoCompletion for virtual keyboard(‘plugin://plugin.program.autocompletion/’,‘11’,‘?info=autocomplete&&id=hol&&limit=12’,‘resume:false’)
2019-04-23 17:45:48.015 T:1353401056 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-04-23 17:45:48.015 T:1353401056 INFO: initializing python engine.
2019-04-23 17:45:48.015 T:1353401056 DEBUG: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): start processing
2019-04-23 17:45:48.277 T:1742717664 DEBUG: PushCecKeypress - received key b duration 281 (rep:0 size:0)
2019-04-23 17:45:48.277 T:1742717664 DEBUG: PushCecKeypress - ignored key b
2019-04-23 17:45:48.390 T:1403757280 DEBUG: version 1.0.1 started
2019-04-23 17:45:48.541 T:1403757280 DEBUG: CAddonSettings[plugin.program.autocompletion]: loading setting definitions
2019-04-23 17:45:48.541 T:1403757280 DEBUG: CAddonSettings[plugin.program.autocompletion]: trying to load setting definitions from old format…
2019-04-23 17:45:48.647 T:1403757280 DEBUG: plugin.program.autocompletion: opened textfile /home/osmc/.kodi/userdata/addon_data/plugin.program.autocompletion/Google/46b93c58c195f7b107c89128755f4e92.txt.
2019-04-23 17:45:48.736 T:1403757280 DEBUG: plugin.program.autocompletion: loaded file for http://clients1.google.com/complete/search?hl=en&q=ho&json=t&client=serp&ds=yt. time: 0.193182
2019-04-23 17:45:48.931 T:1353401056 DEBUG: -->Python Interpreter Initialized<–
2019-04-23 17:45:48.931 T:1353401056 DEBUG: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): the source file to load is “/home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py”
2019-04-23 17:45:48.933 T:1353401056 DEBUG: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): setting the Python path to /home/osmc/.kodi/addons/plugin.program.autocompletion:/home/osmc/.kodi/addons/script.module.autocompletion/lib:/home/osmc/.kodi/addons/script.module.simplejson/lib:/usr/lib/python2.7:/usr/lib/python2.7/plat-arm-linux-gnueabihf:/usr/lib/python2.7/lib-tk:/usr/lib/python2.7/lib-old:/usr/lib/python2.7/lib-dynload:/usr/local/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages:/usr/lib/python2.7/dist-packages/PILcompat:/usr/lib/python2.7/dist-packages/gtk-2.0
2019-04-23 17:45:48.933 T:1353401056 DEBUG: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): entering source directory /home/osmc/.kodi/addons/plugin.program.autocompletion
2019-04-23 17:45:48.933 T:1353401056 DEBUG: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): instantiating addon using automatically obtained id of “plugin.program.autocompletion” dependent on version 2.24.0 of the xbmc.python api
2019-04-23 17:45:49.216 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2019-04-23 17:45:49.216 T:1742717664 DEBUG: PushCecKeypress - added key a7
2019-04-23 17:45:49.220 T:1915762224 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, action is Down
2019-04-23 17:45:49.403 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 187 (rep:0 size:0)
2019-04-23 17:45:49.403 T:1742717664 DEBUG: PushCecKeypress - ignored key a7
2019-04-23 17:45:49.551 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2019-04-23 17:45:49.551 T:1742717664 DEBUG: PushCecKeypress - added key a7
2019-04-23 17:45:49.570 T:1915762224 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, action is Down
2019-04-23 17:45:49.703 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 152 (rep:0 size:0)
2019-04-23 17:45:49.703 T:1742717664 DEBUG: PushCecKeypress - ignored key a7
2019-04-23 17:45:50.096 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2019-04-23 17:45:50.096 T:1742717664 DEBUG: PushCecKeypress - added key a7
2019-04-23 17:45:50.103 T:1915762224 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, action is Down
2019-04-23 17:45:50.267 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 171 (rep:0 size:0)
2019-04-23 17:45:50.267 T:1742717664 DEBUG: PushCecKeypress - ignored key a7
2019-04-23 17:45:50.512 T:1353401056 DEBUG: version 1.0.1 started
2019-04-23 17:45:50.553 T:1353401056 DEBUG: CAddonSettings[plugin.program.autocompletion]: loading setting definitions
2019-04-23 17:45:50.554 T:1353401056 DEBUG: CAddonSettings[plugin.program.autocompletion]: trying to load setting definitions from old format…
2019-04-23 17:45:50.605 T:1403757280 DEBUG: finished
2019-04-23 17:45:50.605 T:1403757280 INFO: CPythonInvoker(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): script successfully run
2019-04-23 17:45:50.605 T:1403757280 DEBUG: onExecutionDone(59, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py)
2019-04-23 17:45:50.746 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 0 (rep:0 size:0)
2019-04-23 17:45:50.746 T:1742717664 DEBUG: PushCecKeypress - added key a7
2019-04-23 17:45:50.753 T:1915762224 DEBUG: HandleKey: 167 (0xa7, obc88) pressed, trying keyboard action 4
2019-04-23 17:45:50.922 T:1742717664 DEBUG: PushCecKeypress - received key a7 duration 176 (rep:0 size:0)
2019-04-23 17:45:50.922 T:1742717664 DEBUG: PushCecKeypress - ignored key a7
2019-04-23 17:45:50.967 T:1403757280 INFO: Python interpreter stopped
2019-04-23 17:45:50.967 T:1403757280 DEBUG: Thread LanguageInvoker 1403757280 terminating
2019-04-23 17:45:51.164 T:1353401056 DEBUG: plugin.program.autocompletion: download http://clients1.google.com/complete/search?hl=en&q=hol&json=t&client=serp&ds=yt. time: 0.608568
2019-04-23 17:45:51.169 T:1353401056 DEBUG: plugin.program.autocompletion: saved textfile /home/osmc/.kodi/userdata/addon_data/plugin.program.autocompletion/Google/b67b27c1009ea36a97a668be66b03e6f.txt. Time: 0.003664
2019-04-23 17:45:51.189 T:1353401056 DEBUG: finished
2019-04-23 17:45:51.189 T:1353401056 INFO: CPythonInvoker(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): script successfully run
2019-04-23 17:45:51.190 T:1353401056 DEBUG: onExecutionDone(60, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py)
2019-04-23 17:45:51.540 T:1353401056 INFO: Python interpreter stopped
2019-04-23 17:45:51.540 T:1353401056 DEBUG: Thread LanguageInvoker 1353401056 terminating
2019-04-23 17:45:52.356 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
2019-04-23 17:45:52.356 T:1742717664 DEBUG: PushCecKeypress - added key a6
2019-04-23 17:45:52.370 T:1915762224 DEBUG: HandleKey: 166 (0xa6, obc89) pressed, action is Up
2019-04-23 17:45:52.556 T:1742717664 DEBUG: PushCecKeypress - received key a6 duration 200 (rep:0 size:0)
2019-04-23 17:45:52.556 T:1742717664 DEBUG: PushCecKeypress - ignored key a6
2019-04-23 17:45:53.251 T:1742717664 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
2019-04-23 17:45:53.251 T:1742717664 DEBUG: PushCecKeypress - added key b
2019-04-23 17:45:53.286 T:1915762224 DEBUG: HandleKey: 11 (0x0b, obc244) pressed, action is Select
2019-04-23 17:45:53.304 T:1915762224 DEBUG: StartScript - calling plugin AutoCompletion for virtual keyboard(‘plugin://plugin.program.autocompletion/’,‘12’,‘?info=selectautocomplete&&id=hola’,‘resume:false’)
2019-04-23 17:45:53.310 T:1353401056 DEBUG: Thread LanguageInvoker start, auto delete: false
2019-04-23 17:45:53.311 T:1353401056 INFO: initializing python engine.
2019-04-23 17:45:53.311 T:1353401056 DEBUG: CPythonInvoker(61, /home/osmc/.kodi/addons/plugin.program.autocompletion/plugin.py): start processing
2019-04-23 17:45:53.331 T:1403757280 DEBUG: Thread scriptobs start, auto delete: false
2019-04-23 17:45:53.427 T:1742717664 DEBUG: PushCecKeypress - received key b duration 176 (rep:0 size:0)
2019-04-23 17:45:53.427 T:1742717664 DEBUG: PushCecKeypress - ignored key b
