well, sometimes i reboot the osmc to update libraries etc. but this time, i cant see kodi, just i cant see it. HMDI is ok(tasted), tv is ok(tasted), and i can acces osmc by using ssh and my HD on nfs protocol. And i repeat, i cant see, its important because kodi works ok, using yatse pluggin for android i can play any video on my cellphone from osmc.
Anyone can help me?
Login via ssh and post the URL that grab-logs -A gives you
And also output of
tvservice -s
tvservice -m CEA
tvservice -m DMT
osmc@osmc:~$ grab-logs -A
Logs successfully uploaded.
Logs available at http://paste.osmc.io/{“message”:"Documentexceedsmaximumlength.
osmc@osmc:~$ tvservice -s
state 0x40001 [NTSC 4:3], 720x480 @ 60.00Hz, interlaced
osmc@osmc:~$ tvservice -m CEA
Group CEA has 0 modes:
osmc@osmc:~$ tvservice -m DMT
Group DMT has 0 modes:
Unfortunately your logs didn’t upload as they are too big.
And as you can see there are also no proper videomodes reported.
Suggest:
- To crosscheck once more the HDMI cable
- Power down OSMC disconnect OSMC and TV from power for a few minutes
- Connect TV to power and then power-up the OSMC
After that repost the commands.
That means we are outputting to composite. That means TV wasn’t detected through HDMI.
Are you sure TV was powered on and on right AV input when you booted?
Lol, diconect and conect works. Thanks everyone. ![:wink: :wink:](https://discourse.osmc.tv/images/emoji/twitter/wink.png?v=9)
If you always connect to the same TV you can save the TV’s edid to a file. That means you no longer have to ensure TV is powered on first. See:
http://kodi.wiki/view/Raspberry_Pi_FAQ#TV_is_not_detected_unless_powered_on_first
