I have got my hd44780 display to work, but still need help
Well like I said I did get the lcd diplay to work but all I am getting is a bunch of random characters to display. Could someone help, I would like it to show the menu info of Kodi and do not know where I want wrong.
would be greatly appreciated.
All good got it working.
Maybe you can share a quick howto so others know what to do if they have the same module
  1. In OMSC menu > Updating (Scan for updates now)
  2. sudo apt-get update
    sudo apt-get install lcdproc lcdproc-extra-drivers
    (select “Yes” perform auto config upgrade)
  3. sudo apt-get install dpkg-dev gcc
  4. sudo apt-get install build-essential
  5. Then Uninsall lcdproc:
    sudo apt-get remove lcdproc
  6. Reinstall lcdproc.
  7. Then copied the patched hd47780.so file from here http://collaborate.osmc.tv/index.php/s/prPuDAFVUSk1wWT/download over the existing one in /usr/lib/arm-linux-gnueabihf/lcdproc/
    All thanks to goes to @mcobit for the working hd44780.so
  8. Then edited the configfile /etc/LCDd.conf to look like this:
    This file was written by cme command.
    You can run ‘cme edit ’ to modify this file.
    Run ‘cme list’ to get the list of applications available on your system
    You may also modify the content of this file with your favorite editor.
    #Driver=hd44780
    #DriverPath=/usr/lib/arm-linux-gnueabihf/lcdproc/
    Hitachi HD44780 driver
    [hd44780]
    ConnectionType=raspberrypi
    D7=18
    D6=23
    D5=24
    D4=25
    RS=7
    EN=8
    Size=16x2
    LCDd.conf
    This file contains the configuration for the LCDd server.
    The format is ini-file-like. It is divided into sections that start at
    markers that look like [section]. Comments are all line-based comments,
    and are lines that start with ‘#’ or ‘;’.
    The server has a ‘central’ section named [server]. Further each driver
    has a section which defines how the driver acts.
    The drivers are activated by specifiying them in a driver= line in the
    server section, like:
    Driver=curses
    This tells LCDd to use the curses driver. The first driver that is
    loaded and is capable of output becomes ‘the’ output driver.
    All extra drivers can only serve as input.
    The default driver to use is curses.
    The drivers can read their own options from the config file, but most of
    them don’t do this yet. They expect ‘command-line’-format parameters that
    were previously placed on the command line. These parameters can be
    given to the driver in the following way:
    Arguments=“place arguments here”
    The arguments between the quotes are passed to the driver.
    As said before these are the same arguments that the driver would have
    been passed under the old command line format of
    -d “”
    Note that the -d option still works, but not allows driverargs anymore.
    If -d is specified on the command line, the Driver= options in the
    config file are ignored.
    [server]
    Server section with all kinds of settings for the LCDd server
    #Driver=none
    #Driver=curses
    Driver=hd44780
    #Driver=lcdm001
    #Driver=MtxOrb
    #Driver=CFontz
    Tells the server to load the given drivers. Multiple lines can be given.
    NOTE: You may activate several input (input only) drivers but only ONE output
    driver, which should be the first.
    Bind=127.0.0.1
    Tells the driver to bind to the given interface
    Port=13666
    Listen on this specified port; defaults to 13666.
    #ReportLevel=5
    Sets the reporting level; defaults to 2 (warnings and errors only).
    ReportLevel=0 means NO DEBUG. This will avoid a flood of syslog …
    ReportToSyslog=no
    Should we report to syslog instead of stderr ? Default: no
    WaitTime=5
    Sets the default time in seconds to displays a screen.
    User=nobody
    User to run as. LCDd will drop its root priviledges,
    if any, and run as this user instead.
    ServerScreen=no
    Enables the built-in server screen [Default: no]
    yes : always,
    no : when there are no other screens active.
    Foreground=no
    The server will stay in the foreground if set to true.
    Otherwise the server will fork to background and report
    to syslog
    TIP: The following options can also be modified from the
    server menu (which requires a driver that supports input)
    Heartbeat=open
    The server has serveral heartbeat modes
    on Stays on all the time
    off Stays off all the time
    slash Rotating slash all the time
    open Can be controlled by all clients
    InitialHeartbeat=on
    This sets the initial heartbeat state if the heartbeat mode is “open”
    Affects the server screen only :wink:
    on Heartbeat activated
    off Heartbeat disabled
    slash Heartbeat replaced with a rotating slash
    Backlight=open
    The server has serveral backlight modes
    InitialBacklight=on
    This sets the initial backlight state if the backlight mode is “open”
    BacklightBrightness=255
    This sets the backlight brightness in state “on”
    NOTE: Not all drivers/devices support setting the brightness this
    way. Some don’t support switching the backlight on/off at all,
    some can switch the backlight on or off only. If the latter is
    the case BacklightBrightness must be > 0.
    BacklightOffBrightness=0
    This sets the backlight brightness in state “off”
    the case BacklightBrightness must be = 0.
    [input]
    Input section with settings that are related to input handling
    NOTE: Not all drivers have input functionality
    keypad settings
    Keyname Function
    Normal context Menu context
    PauseKey Pause/Continue Enter/select
    BackKey Back(Go to previous screen) Up/Left
    ForwardKey Forward(Go to next screen) Down/Right
    MainMenuKey Open main menu Exit/Cancel
    #FreePauseKey=yes
    If set to yes, this prevents LCDd from handling the PauseKey itself
    #FreeBackKey=yes
    If set to yes, this prevents LCDd from handling the BackKey itself
    #FreeForwardKey=yes
    If set to yes, this prevents LCDd from handling the ForwardKey itself
    #FreeMainMenuKey=no
    If set to yes, this prevents LCDd from handling the MainMenuKey itself
    TIP: Even if you “free” the above keys, you can still use the menu
    provided you set FreeMainMenuKey=no
  9. Install LCDproc via OSMC
    In the OSMC manin menu got to Settings >> Add-ons >> Get add-ons >> XBMC/Kodi add-on repository >> Services >> XBMC LCDproc >> Install
  10. sudo /etc/init.d/LCDd restart
Done
Great, appreciate
Glad i could help, hope it works for you.
On the pictures above i forgot to input a rotary potentiometer at pin 3 of lcd. It is used to adjust contrast. 1KΩ will do the work i guess, still i am working with one 9.9KΩ.
A full guide from @szalay and @Oscillation_Station at (1st and 24rth post at that thread)
and
