If my OSMC Pi boots without display switched on, when I switch it on I get no output whereas if I boot with my TV already switched on I get the output.
Is there any way to set it to boot with a video output regardless of if my display is switched on yet?
I have root access to my Pi via SSH.
Any help would be appreciated.
try adding the following lines in config.txt
hdmi_group=1
hdmi_mode=16
hdmi_force_hotplug=1
hdmi_edid_file=1
hdmi_mode=16 will set your screen to 1080p 60hz. If your tv is different check the number code in
Thanks! I will try this tomorrow and get back to you!
Just to confirm that this is the /boot/config.txt file?
Thanks again!
This seems to have worked, will keep testing over the next few days! Thanks
