[ 0.000000] Booting Linux on physical CPU 0xf00
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 3.18.13-1-osmc (root@vero) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Sun May 17 18:50:26 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 2 Model B
[ 0.000000] cma: Reserved 8 MiB at 0x2e800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 809abd80, node_mem_map ae213000
[ 0.000000] Normal zone: 1504 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (8640->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 10 pages/cpu @ae1e1000 s12096 r8192 d20672 u40960
[ 0.000000] pcpu-alloc: s12096 r8192 d20672 u40960 alloc=10*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 191008
[ 0.000000] Kernel command line: dma.dmachans=0x7f35 bcm2708_fb.fbwidth=1920 bcm2708_fb.fbheight=1080 bcm2709.boardrev=0xa01041 bcm2709.serial=0xad759f00 smsc95xx.macaddr=B8:27:EB:75:9F:00 bcm2708_fb.fbswap=1 bcm2709.disk_led_gpio=47 bcm2709.disk_led_active_low=0 sdhci-bcm2708.emmc_clock_freq=250000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 744108K/770048K available (7249K kernel code, 401K rwdata, 1864K rodata, 388K init, 763K bss, 25940K reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xffe00000 (2048 kB)
vmalloc : 0xaf800000 - 0xff000000 (1272 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x808ee928 (9115 kB)
.init : 0x808ef000 - 0x80950000 ( 388 kB)
.data : 0x80950000 - 0x809b465c ( 402 kB)
.bss : 0x809b465c - 0x80a73594 ( 764 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] NR_IRQS:608
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (virt).
[ 0.000014] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 3579139424256ns
[ 0.000037] Switching to timer-based delay loop, resolution 52ns
[ 0.000319] Console: colour dummy device 80x30
[ 0.000522] console [tty0] enabled
[ 0.000547] Calibrating delay loop (skipped), value calculated using timer frequency.. 38.40 BogoMIPS (lpj=192000)
[ 0.000575] pid_max: default: 32768 minimum: 301
[ 0.000963] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000985] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.002220] Initializing cgroup subsys memory
[ 0.002271] Initializing cgroup subsys devices
[ 0.002295] Initializing cgroup subsys freezer
[ 0.002318] Initializing cgroup subsys net_cls
[ 0.002353] Initializing cgroup subsys blkio
[ 0.002431] CPU: Testing write buffer coherency: ok
[ 0.002508] ftrace: allocating 18151 entries in 54 pages
[ 0.046771] CPU0: update cpu_capacity 1024
[ 0.046810] CPU0: thread -1, cpu 0, socket 15, mpidr 80000f00
[ 0.046829] [bcm2709_smp_prepare_cpus] enter
[ 0.046968] Setting up static identity map for 0x6aeea8 - 0x6aef00
[ 0.106712] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.107019] CPU1: Booted secondary processor
[ 0.107028] [bcm2709_secondary_init] enter cpu:1
[ 0.107081] CPU1: update cpu_capacity 1024
[ 0.107089] CPU1: thread -1, cpu 1, socket 15, mpidr 80000f01
[ 0.126693] [bcm2709_boot_secondary] cpu:2 started (0) 18
[ 0.126947] CPU2: Booted secondary processor
[ 0.126953] [bcm2709_secondary_init] enter cpu:2
[ 0.126986] CPU2: update cpu_capacity 1024
[ 0.126994] CPU2: thread -1, cpu 2, socket 15, mpidr 80000f02
[ 0.146716] [bcm2709_boot_secondary] cpu:3 started (0) 18
[ 0.146952] CPU3: Booted secondary processor
[ 0.146959] [bcm2709_secondary_init] enter cpu:3
[ 0.146988] CPU3: update cpu_capacity 1024
[ 0.146996] CPU3: thread -1, cpu 3, socket 15, mpidr 80000f03
[ 0.147088] Brought up 4 CPUs
[ 0.147122] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.147133] CPU: All CPU(s) started in SVC mode.
[ 0.148137] devtmpfs: initialized
[ 0.173080] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.175124] pinctrl core: initialized pinctrl subsystem
[ 0.178060] NET: Registered protocol family 16
[ 0.183404] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.206530] cpuidle: using governor ladder
[ 0.236554] cpuidle: using governor menu
[ 0.236689] bcm2709.uart_clock = 3000000
[ 0.239477] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.239498] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.239530] mailbox: Broadcom VideoCore Mailbox driver
[ 0.239644] bcm2708_vcio: mailbox at f300b880
[ 0.239989] bcm_power: Broadcom power driver
[ 0.240007] bcm_power_open() -> 0
[ 0.240018] bcm_power_request(0, 8)
[ 0.740682] bcm_mailbox_read -> 00000080, 0
[ 0.740695] bcm_power_request -> 0
[ 0.740815] Serial: AMBA PL011 UART driver
[ 0.740944] dev:f1: ttyAMA0 at MMIO 0x3f201000 (irq = 83, base_baud = 0) is a PL011 rev3
[ 0.809082] SCSI subsystem initialized
[ 0.809329] usbcore: registered new interface driver usbfs
[ 0.809432] usbcore: registered new interface driver hub
[ 0.809583] usbcore: registered new device driver usb
[ 0.811198] Switched to clocksource arch_sys_counter
[ 0.838701] FS-Cache: Loaded
[ 0.839021] CacheFiles: Loaded
[ 0.850621] NET: Registered protocol family 2
[ 0.851990] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.852133] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.852326] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.852436] TCP: reno registered
[ 0.852459] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852523] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.852993] NET: Registered protocol family 1
[ 0.853425] RPC: Registered named UNIX socket transport module.
[ 0.853441] RPC: Registered udp transport module.
[ 0.853451] RPC: Registered tcp transport module.
[ 0.853462] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.853922] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.854147] bcm2708_dma: DMA manager at f3007000
[ 0.854308] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 0.855917] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.856133] audit: initializing netlink subsys (disabled)
[ 0.856195] audit: type=2000 audit(0.829:1): initialized
[ 0.872096] VFS: Disk quotas dquot_6.5.2
[ 0.872471] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.875445] FS-Cache: Netfs 'nfs' registered for caching
[ 0.876450] NFS: Registering the id_resolver key type
[ 0.876521] Key type id_resolver registered
[ 0.876533] Key type id_legacy registered
[ 0.877562] msgmni has been set to 1469
[ 0.879556] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.879749] io scheduler noop registered
[ 0.880055] io scheduler bfq registered (default)
[ 0.880067] BFQ I/O-scheduler version: v7r7
[ 0.882542] BCM2708FB: allocated DMA memory eec00000
[ 0.882588] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.916251] Console: switching to colour frame buffer device 240x67
[ 0.938445] bcm2708-dmaengine bcm2708-dmaengine: Load BCM2835 DMA engine driver
[ 0.938762] uart-pl011 dev:f1: no DMA platform data
[ 0.939241] vc-cma: Videocore CMA driver
[ 0.939255] vc-cma: vc_cma_base = 0x00000000
[ 0.939268] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 0.939279] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 0.950836] brd: module loaded
[ 0.956777] loop: module loaded
[ 0.957589] vchiq: vchiq_init_state: slot_zero = 0xaec80000, is_master = 0
[ 0.958440] Loading iSCSI transport class v2.0-870.
[ 0.959404] usbcore: registered new interface driver smsc95xx
[ 0.959485] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.159852] Core Release: 2.80a
[ 1.159875] Setting default values for core params
[ 1.159903] Finished setting default values for core params
[ 1.360296] Using Buffer DMA mode
[ 1.360313] Periodic Transfer Interrupt Enhancement - disabled
[ 1.360323] Multiprocessor Interrupt Enhancement - disabled
[ 1.360336] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.360353] Dedicated Tx FIFOs mode
[ 1.360714] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xaec14000 dma = 0xeec14000 len=9024
[ 1.360754] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
[ 1.360779] dwc_otg: Microframe scheduler enabled
[ 1.360850] WARN::hcd_init_fiq:412: FIQ on core 1 at 0x804f8c30
[ 1.360870] WARN::hcd_init_fiq:413: FIQ ASM at 0x804f8fa0 length 36
[ 1.360891] WARN::hcd_init_fiq:438: MPHI regs_base at 0xaf80a000
[ 1.360918] dwc_otg bcm2708_usb: DWC OTG Controller
[ 1.360969] dwc_otg bcm2708_usb: new USB bus registered, assigned bus number 1
[ 1.361017] dwc_otg bcm2708_usb: irq 32, io mem 0x00000000
[ 1.361072] Init: Port Power? op_state=1
[ 1.361083] Init: Power Port (0)
[ 1.361469] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.361490] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.361506] usb usb1: Product: DWC OTG Controller
[ 1.361522] usb usb1: Manufacturer: Linux 3.18.13-1-osmc dwc_otg_hcd
[ 1.361537] usb usb1: SerialNumber: bcm2708_usb
[ 1.362534] hub 1-0:1.0: USB hub found
[ 1.362602] hub 1-0:1.0: 1 port detected
[ 1.363131] dwc_otg: FIQ enabled
[ 1.363145] dwc_otg: NAK holdoff enabled
[ 1.363155] dwc_otg: FIQ split-transaction FSM enabled
[ 1.363198] Module dwc_common_port init
[ 1.363591] usbcore: registered new interface driver usb-storage
[ 1.363879] mousedev: PS/2 mouse device common for all mice
[ 1.364793] bcm2835-cpufreq: min=600000 max=1000000
[ 1.365123] sdhci: Secure Digital Host Controller Interface driver
[ 1.365136] sdhci: Copyright(c) Pierre Ossman
[ 1.365326] DMA channels allocated for the MMC driver
[ 1.401233] Load BCM2835 MMC driver
[ 1.401539] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.405413] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.407761] hidraw: raw HID events driver (C) Jiri Kosina
[ 1.408089] usbcore: registered new interface driver usbhid
[ 1.408101] usbhid: USB HID core driver
[ 1.409481] TCP: cubic registered
[ 1.409504] Initializing XFRM netlink socket
[ 1.409555] NET: Registered protocol family 17
[ 1.409833] Key type dns_resolver registered
[ 1.410013] Registering SWP/SWPB emulation handler
[ 1.413401] registered taskstats version 1
[ 1.415846] vc-sm: Videocore shared memory driver
[ 1.415867] [vc_sm_connected_init]: start
[ 1.416759] [vc_sm_connected_init]: end - returning 0
[ 1.417789] Waiting for root device /dev/mmcblk0p2...
[ 1.438811] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.440951] mmc0: new high speed SDHC card at address 1234
[ 1.441618] mmcblk0: mmc0:1234 SA16G 14.6 GiB
[ 1.443200] mmcblk0: p1 p2
[ 1.524027] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 1.524051] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 1.561361] Indeed it is in host mode hprt0 = 00021501
[ 1.741317] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 1.741499] Indeed it is in host mode hprt0 = 00001101
[ 1.941592] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 1.941618] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.942642] hub 1-1:1.0: USB hub found
[ 1.942747] hub 1-1:1.0: 5 ports detected
[ 2.221337] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.321541] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.321566] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.324552] smsc95xx v1.0.4
[ 2.385052] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-bcm2708_usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:75:9f:00
[ 2.461327] usb 1-1.2: new low-speed USB device number 4 using dwc_otg
[ 2.584211] usb 1-1.2: New USB device found, idVendor=09da, idProduct=024f
[ 2.584237] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.584253] usb 1-1.2: Product: RF USB Receiver
[ 2.584268] usb 1-1.2: Manufacturer: A4Tech
[ 2.598764] input: A4Tech RF USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.0/0003:09DA:024F.0001/input/input0
[ 2.599132] hid-generic 0003:09DA:024F.0001: input,hidraw0: USB HID v1.11 Keyboard [A4Tech RF USB Receiver] on usb-bcm2708_usb-1.2/input0
[ 2.620871] input: A4Tech RF USB Receiver as /devices/platform/bcm2708_usb/usb1/1-1/1-1.2/1-1.2:1.1/0003:09DA:024F.0002/input/input1
[ 2.621614] hid-generic 0003:09DA:024F.0002: input,hidraw1: USB HID v1.11 Mouse [A4Tech RF USB Receiver] on usb-bcm2708_usb-1.2/input1
[ 2.701325] usb 1-1.4: new high-speed USB device number 5 using dwc_otg
[ 2.801970] usb 1-1.4: New USB device found, idVendor=0bda, idProduct=8179
[ 2.801993] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 2.802010] usb 1-1.4: Product: 802.11n NIC
[ 2.802026] usb 1-1.4: Manufacturer: Realtek
[ 2.802041] usb 1-1.4: SerialNumber: 00E04C0001
[ 5.593037] random: nonblocking pool is initialized
[ 12.111320] EXT4-fs (mmcblk0p2): recovery complete
[ 12.116769] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 12.116852] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 12.122914] devtmpfs: mounted
[ 12.123583] Freeing unused kernel memory: 388K (808ef000 - 80950000)
[ 14.220015] NET: Registered protocol family 10
[ 14.704538] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 14.704924] systemd[1]: Found ordering cycle on basic.target/start
[ 14.704956] systemd[1]: Found dependency on sysinit.target/start
[ 14.704985] systemd[1]: Found dependency on kbd.service/start
[ 14.705015] systemd[1]: Found dependency on remote-fs.target/start
[ 14.705041] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 14.705066] systemd[1]: Found dependency on connman.service/start
[ 14.705090] systemd[1]: Found dependency on basic.target/start
[ 14.705117] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 14.705149] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 14.917530] fuse init (API version 7.23)
[ 15.042223] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 15.147090] systemd-udevd[115]: starting version 215
[ 15.680916] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 15.705822] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 15.743389] usbcore: registered new interface driver r8188eu
[ 15.871354] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 16.946245] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[ 17.870091] systemd-journald[93]: Received request to flush runtime journal from PID 1
[ 18.775040] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 18.775237] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 19.481633] MAC Address = 14:cc:20:1c:d8:9b
[ 19.484137] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 19.557125] cfg80211: Calling CRDA to update world regulatory domain
[ 22.119656] R8188EU: ERROR assoc success
[ 22.120118] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
[ 25.096422] Console: switching to colour dummy device 80x30
