Hi, I’ve got a 2.35:1 projector screen and I wondered if I could shift this image down so its in the bottom of the image and is it possible to scale 16x9 video to fit in the 2.35:1 screen area? Thanks
have you seen that there is a OSMC Skin (Scope Edition) available at settings -> interface -> skin?
Yes thanks but that applies only to the skin. I’ve seen I can shrink the image down to fit in a 16x9 image in a 2.35:1 area but I don’t think vertical shift works.
In theory this is possible for video playback – there are references to things like keystone correction; but we’ve not looked in to it in the past.
Does your projector support keystone correct?
So the zoom function seems to do exactly what I want it to do but I would like to assign a zoom amount (e.g. 0.74) to a hotkey - is this possible? Thanks
You might be able to do it using the Keymap Editor add-on.
Unfortunately not
