I’m not sure if that comes from last update, I think it was present before.
The “in progress” in default skin is not updated, I tried to change the skins and coming back to default one I got a message saying I shall upload the log: https://paste.osmc.tv/alurifahup
Do you see anything that might be the rootcause here ?
That is only a Kernel log, we need all logs ideally with debugging enabled (see below).
Also maybe take a picture what you mean with “in progress” you mean Movies that are “in progress”?
reproduce the issue
Thanks for your reply and sorry for the lack of information, you are correct on the “in progress” fields, TV shows and movies.
Here is new log: https://paste.osmc.tv/nugodisure
During each both boot I got a sad smiley, don’t know if it’s normal… shall not right ?
If I use the website thourgh my Vero IP I can see the right status for “in progress”, it looks connected to a build process (btw I got this when I swap skins, this shold be present in the log).
