Looks like i can’t use remote access to my rpi. I can ping the hostname just fine and it resolves the correct IP however when using the opened ports (opened on the router) it just takes too long then gives me a time out. It was working just fine but i removed network manager last time after i installed it to get rid of OPENVPN. I can access other machines on the same network correctly but everyhting on OSMC machine is a no go.
You’ve probably messed up your box by installing network manager. One possibility is that there are some iptables rules still lurking, Try this from the command line:
sorry for the confusion. what i mean is, when i type hostname:port i can’t access that. For example SSH, TRANSMISSION, SICKRAGE, are all on different ports and none are accessible. Im not connecting through VPN i dunno why its running though, must be the old install
I just removed forwarding port for SSH from the router, it immediatly tells me that the connection is refused. When i add it back it just hangs and time out
sure, http://xxxx.ddns.net/ on my browser gives me the access to my router http://xxxx.ddns.net:4141 on my browser should give me access to sickrage interface which is running on my RPI but it doesnt, it just says :The server at xxxx.ddns.net is taking too long to respond.
So within your LAN, http://<Pi Address>:4141 successfully goes to the sickrage interface, correct? If so, the Pi is working just fine but your router isn’t working correctly and the first thing to do is reboot it.
That said, IMO you are just asking for trouble port forwarding straight to machines on your LAN. Really, you should only be allowing either SSH or OpenVPN through your router or something bad can easily happen. End of sermon.
So within your LAN, http://:4141 successfully goes to the sickrage interface, correct?
yep correct. Already rebooted the router and removed all port forwarding yet re-adding them leads to same error.
yes i know but i only have sickrage and transmission running and ssh is on a non standard port as are the other 2 also using a very strong password i can’t even remember
I know little about sickrage but transmission has a config option rpc-whitelist that defines which IP addresses can access the interface. It’s worth checking out.
yup tahts what 'im planing on doing this weekend. Any particular way to reinstall?trying to lose the least possible configs. Isn’t there a function to just reinstall instead of wiping the sd card and installing over?
