Have two rpi2 with both on the latest OSMC, for some reason one is showing the incorrect time. Have gone into System->Appearance->.International and the country setting is correct, but it does not allow me to change the Time Zone or TimeZone Country, as a matter of fact both settings are blank. Any suggestions or modifications to one of the *.xml files.
Yes, understand that, put just wanted to post a snippet of the code in the forum. Editor mucks it up. What are the opening and closing statements to post code in a post?
You would have to use the “Preformatted Text” button that is </> button.
But as Sam wrote it doesn’t help if you post the file. Stop Kodi, rename/move the file, start Kodi
Thanks, will try that. I have already renamed the file, restarted and it still is exhibiting the same problem. Wanted to post a copy of the locale setting of the GUIsettings.xml if anyone can see something wrong.
There can not be anything wrong if it just cleanly was recreated.
I think showing the screenshot of System -> Apperance -> International would make more sense
