Since I updated my raspberry pi B to RC3 I cannot access my usb hard disk from windows using samba. I’m using default samba config files and I am mounting my hard disk using fstab as follows:
Every time I try to access this share it asks for password and osmc:osmc is not valid, any other share is working correctly.I installed samba with app store. The /mnt/RaspberryPi directory was made using “sudo mkdir /mnt/RaspberryPi” and then “sudo chown -R osmc:osmc /mnt/RaspberryPi”
I was trying to add this drive using smb-shares.conf but after some tests I gave up and deleted smb-local.conf and the lines added to smb-shares.conf. There is nothing in /media. My drive is the share list, so I guess that it is being shared by default.
ls -la /mnt /media /etc/samba
/etc/samba:
total 36
drwxr-xr-x 3 root root 4096 May 20 00:55 .
drwxr-xr-x 75 root root 4096 May 22 19:50 ..
-rw-r--r-- 1 root root 8 Mar 7 13:14 gdbcommands
-rw-r--r-- 1 root root 329 May 20 00:55 smb-shares.conf
-rw-r--r-- 1 root root 1657 May 14 23:32 smb.conf
-rw-r--r-- 1 root root 9231 Apr 12 12:28 smb.conf.distributed
drwxr-xr-x 2 root root 4096 Mar 15 15:19 tls
/media:
total 12
drwxr-xr-x 2 root root 4096 May 19 16:12 .
drwxr-xr-x 23 root root 4096 May 15 11:05 ..
-rw-r--r-- 1 root root 232 Mar 6 13:34 README
/mnt:
total 16
drwxr-xr-x 4 root root 4096 May 19 18:02 .
drwxr-xr-x 16 osmc osmc 4096 May 20 01:01 RaspberryPi
drwxr-xr-x 2 osmc osmc 4096 May 19 18:02 WDTV
cat /etc/samba/smb.conf
[global]
# If you require a fully custom smb.conf create smb-local.conf instead of editing smb.conf so your
# configuration will not be overwritten by samba upgrades. You can use smb.conf as a template by
# copying it to smb-local.conf then removing the config file line below in the new file. If you only
# need to add some additional shares see smb-shares.conf below for a simpler way to do this.
config file = /etc/samba/smb-local.conf
workgroup = WORKGROUP
security=user
follow symlinks = yes
wide links = no
unix extensions = no
lock directory = /var/cache/samba
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
log level = 1
map to guest = bad user
usershare template share = automount template
read raw = Yes
write raw = Yes
strict locking = no
min receivefile size = 16384
use sendfile = true
aio read size = 2048
aio write size = 2048
socket options = TCP_NODELAY IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
[osmc]
browsable = yes
read only = no
valid users = osmc
path = /home/osmc
comment = OSMC Home Directory
[automount template]
browseable = yes
-valid = no
valid users = osmc
path = %P
hide files = /$RECYCLE.BIN/System Volume Information/desktop.ini/thumbs.db/
# Add custom shares in smb-shares.conf instead of editing smb.conf so they will not be
# overwritten by samba updates. You can only add new shares to smb-shares.conf, not change
# the default shares or global options. If you need full control see smb-local.conf above.
include = /etc/samba/smb-shares.conf
cat /etc/samba/smb-shares.conf
Deprecated devices share. If you do not need this you can remove it.
[devices]
browsable = yes
read only = no
valid users = osmc
path = /media
force user = root
comment = Deprecated (Please use the Auto-mount Volume shares)
I’m afraid I can’t see how your drive mounted in /mnt is being shared by samba at all.
The default samba config files will share /home/osmc as osmc, and if you have smb-shares.conf from a legacy install will also share /media as the devices share.
In addition udisks-glue.conf will share any automounted drive’s partitions as individual shares based on their partition labels. Nowhere is anything sharing drives mounted under /mnt.
What happens if you comment out your fstab line and reboot - does the drive automount in /media (it should) and get an automatically created share ? (it should)
The device is not automonted at boot unless I start kodi (I disabled it because I don’t want it to be started at boot), this happens since RC3 and that’s why I added the fstab line. But, If I comment the fstab line, reboot and start kodi, the device is automounted and it’s accessible from windows.
After a fresh install everything is working fine, I don’t know what was the problem. Although devices are not automounted unless I start kodi, the fstab option is ok for me. Thank you for your help and your hard work!
Thanks for this, I was sceptical at first but it seems you are right - only FAT32 and NTFS partitions are auto-mounting without Kodi running. This is most unusual and we will look into why this is happening.
This should be fixed now. Please run updates to install an update that I’ve just pushed out, and temporarily comment out your fstab mount for your external drive then reboot.
You should find that your external drive partitions are automounted in /media and shared via samba properly without Kodi launching on startup - please confirm that this is the case.
Thanks for noticing that problem - as I don’t usually test with Kodi disabled I missed it…
Nice, now the disk is automounted at boot as always and it’s accessible via samba. Is there any reason to use the automatic way instead of the line I use in fstab? Glad to help
Use whichever you’re happy with - our intention is to make things as easy as possible by automatically mounting external drives by name when connected, and automatically sharing them with samba if you have samba installed. There were a couple of bugs that were causing this not to work under all circumstances, but I think I have those fixed now.
I’m trying to make this share not to ask for password but it’s impossible so far, Am I doing something wrong?
cat /etc/samba/smb-local.conf
[global]
security = user
wide links = no
load printers = no
printing = bsd
log level = 1
read raw = Yes
write raw = Yes
strict locking = no
use sendfile = true
mangled names = no
[osmc]
browsable = no
read only = no
valid users = osmc
path = /home/osmc
browseable = yes
-valid = no
valid users = osmc
path = %P
[RaspberryPi]
browsable = yes
read only = no
path = /mnt/RaspberryPi
guest ok = yes
force user = osmc
force group = osmc
create mask = 755
directory mask = 755
force create mode = 755
force directory mode = 755
I would suggest under the [RaspberryPi] section to only add this line to your existing lines:
Shouldn’t need anything else. Guest account = root is a bad idea.
It’s not working at the moment because windows uses the guest account for unauthenticated shares, but the guest account doesn’t exist on OSMC by default. map to guest = bad user means any unrecognised username will map to the guest account, then the guest ok = yes and force user and force group will work.
But using that configuration every file I create via samba will be owned by root, right? Before the update to RC3 everything was working fine with a configuration pretty similar to the configuration I’ve posted before. I want every file to be owned by osmc:osmc with that permissions (755), anyway I’ll give it a shot in a while and will post the result
You suggested map to guest = bad password, I suggested map to guest = bad user - check the smb.conf man page for why map to guest = bad password is not ideal.
Two reasons - one is allowing any unauthenticated user (which is what map to guest does) to be able to write files as root is just a really bad idea from a security point of view.
The other reason is I’ve gone to some lengths in RC3 to set up the samba shares and the automounter so that files on all different partition types (fat32, exfat, ext4, ntfs) can be written as the osmc user - this means that kodi and the ftp server are both able to delete and rename files written by samba.
If you map to root (as was default in the devices share in RC2 and earlier) then files written by samba cannot be deleted or renamed by either kodi, an ftp client logged in as osmc, or any programs running as osmc.
