Im really enjoying the Vero 4k so far. The only issue I cannot get round on my setup is that the Vero 4k seems to have a much lower max volume than my previous configuration (Pi2 with the HiFi Berry DAC+ Pro).
My speakers are maxed out along with the audio in the Vero 4k and the sound is about 2/3 of what it was previously. I am using the 3.5mm audio jack. Is there a way to increase the max volume without affecting audio quality?
This works and is definitely the easiest solution.
However, I had some issue with this. At 18db, my mp3 music sounded a bit distorted. Easily solved by going down to 6db. But then some movies became hard to hear (original problem). Got a bit tiring having to use alsamixer to keep toggling as required.
Finally got a 192 KHz DAC for 20€. Feeding it the optical out from the Vero 4K has solved all my problems. The audio quality also does seem to have improved …
All that I am trying to do is pass a flac file from a vero 4k through a toslink via a DAC to a 2 channel rac input in a hifi amp. Sounds simple but when you are a technophobe like me simple things to those in the know are somewhat more challenging for the rest of us.
I suspect that as my dac has only rac outputs it is not multichannel (see above!).
How do I go about disabling passthrough (whatever that might be).
Any help is greatly appreciated.
the alsamixer solution used to work for me, but it doesn’t anymore after the july update.
the value of the DAC Extra Digital Gain item (which was reset to 0db after the update) doesn’t change when attempting to alter it using alsamixer. dmesg displays the message It has risk of distortion! each time i attempt to alter the value. it doesn’t seem to matter if the mediaserver service is runnning or not.
does anyone have similar issues and maybe an idea why the value can’t be changed?
Just to confirm: you’re using the analogue out on the device?
I’ll check this out. There have been a few audio improvements, some of which have come from upstream. I’d be happy to produce some test builds for you if you’re willing to give them a try, but it might take me a couple of days to backtrack and see what’s changed.
yes @sam_nazarko, i’m currently using the analogue audio jack (with an audio 2.0 channel configuration in kodi in case it matters). i would be happy to help any way i can.
Add the following line: deb http://apt.osmc.tv jessie-devel main
unfortunately, the change didn’t help, the issue persists.
dmesg does not display any susipcious messages anymore when i attempt to change the value using alsamixer.
these packages were affected by the upgrade: The following NEW packages will be installed: vero364-image-3.14.29-29-osmc:arm64 The following packages will be upgraded: armv7-splash-osmc vero364-kernel-osmc:arm64
the system waited indefinitely while shutting down, displaying the message "A start job is running for Store Sound Card State", so i had to plug the power cord out (i am logging in via SSH). this also happended when rebooting after applying the july update.
a stack trace involving the sound card was displayed while shutting down, but i don’t know how to capture it since i was already disconnected.
