Good day @MitraMAi
Many thanks for your response, apologies for my belated response.
Your assistance in this matter is much appreciated!
Correct, I am trying the second link.
The Snap installation goes well, however when I run the sudo /snap/bin/sickgear command I encounter errors as per the below:
osmc@osmc:~$ sudo snap install sickgear
sickgear 0.25.25 from SickGear installed
osmc@osmc:~$ which sickgear
/snap/bin/sickgear
osmc@osmc:~$ sudo /snap/bin/sickgear
ERROR: ld.so: object ‘/usr/lib/libarmmem.so’ from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
Starting up SickGear from /var/snap/sickgear/common/data/config.ini
07:55:58 INFO TORNADO :: Starting SickGear on http://0.0.0.0:8081/
07:55:58 ERROR TORNADO :: Could not start webserver on 8081. Exception: <class ‘socket.error’>, Error: [Errno 1] Operation not permitted
07:56:28 ERROR MAIN :: Unable to start web server, is something else running on port 8081?
07:56:28 ERROR MAIN :: Launching browser and exiting
