Installing OSMC on to Raspberry Pi 3 model B
Nothing happens after the OSMC splash screen. Just a blank screen
The log says installion OK. Tried installing twice, same result.
What do I do now? I would be grateful for any ideas.
Install.log:
Thu Jan 1 00:00:07 1970 Starting OSMC installer
Thu Jan 1 00:00:13 1970 Detecting device we are running on
Thu Jan 1 00:00:13 1970 Mounting boot filesystem
Thu Jan 1 00:00:13 1970 Trying to mount to MNT_BOOT (/mnt/boot)
Thu Jan 1 00:00:13 1970 Using device->boot: /dev/mmcblk0p1 and FS: fat32
Thu Jan 1 00:00:13 1970 Preseed file found, will attempt to parse
Thu Jan 1 00:00:13 1970 Found a definition for storage: sd
Thu Jan 1 00:00:13 1970 Creating root partition
Thu Jan 1 00:00:13 1970 From a root partition of /dev/mmcblk0p2, I have deduced a base device of /dev/mmcblk0
Thu Jan 1 00:00:14 1970 Determined 255 MB as end of first partition
Thu Jan 1 00:00:14 1970 Calling mkpart for device: /dev/mmcblk0 and fs: ext4 with start 257M and end 100%
Thu Jan 1 00:00:16 1970 Calling fmtpart for partition /dev/mmcblk0p2 and fstype ext4
Thu Jan 1 00:00:34 1970 Filesystem label=
OS type: Linux
Block size=4096 (log=2)
Fragment size=4096 (log=2)
Stride=2 blocks, Stripe width=1024 blocks
962880 inodes, 3848704 blocks
192435 blocks (5.00%) reserved for the super user
First data block=0
Maximum filesystem blocks=3942645760
118 block groups
32768 blocks per group, 32768 fragments per group
8160 inodes per group
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912, 819200, 884736, 1605632, 2654208
Allocating group tables: 0/118 done
Writing inode tables: 0/118 done
Creating journal (32768 blocks): done
Writing superblocks and filesystem accounting information: 0/118 2/118 4/118 done
Thu Jan 1 00:00:34 1970 Mounting root
Thu Jan 1 00:00:34 1970 Trying to mount to MNT_ROOT (/mnt/root)
Thu Jan 1 00:00:34 1970 Using device->root: /dev/mmcblk0p2
Thu Jan 1 00:00:34 1970 Extracting files to root filesystem
Thu Jan 1 00:00:34 1970 Starting extract progress…
Thu Jan 1 00:03:30 1970 Extraction of root filesystem completed
Thu Jan 1 00:03:30 1970 Configuring bootloader
Thu Jan 1 00:03:30 1970 Configuring bootloader: moving /boot to appropriate boot partition
Thu Jan 1 00:03:31 1970 Configuring boot cmdline
Thu Jan 1 00:03:31 1970 Configuring /etc/fstab
Thu Jan 1 00:03:31 1970 Successful installation. Dumping log and rebooting system
