Installing 2017.08-1-HDD on ATV1 from USB. I get the message “Install Failed: Can’t mount Bootfs”
Anyone else experience this?
Did you remove the USB after prompted to do so?
During the boot from USB on ATV1? I never saw a prompt to remove the USB.
If you are installing to HDD, you’ll see a prompt to remove USB. You then reboot and install continues from HDD.
