Installer not seeing SD cards on OS X
Device: Raspberry Pi Model B 512mb (SD card, USB);
Using OS X 10.11.
I had Raspbmc, and later OSMC, running fine on my SD card and USB up until two weeks ago, when a family member accidentally removed the USB stick from the Pi.
The Pi didn’t boot after this happened, so I decided to reinstall OSMC on the SD + USB.
Unfortunately, I can’t seem to install OSMC on to any card in any way, whether it be from the installer provided on the website or through the use of dd.
How can I solve this issue? My Linux PC and Windows PC are not available at the moment.
TL/DR:
  • OSMC installer not working on OS X 10.11
  • dd command not working either; no reaction.
  • sudo dd if=~/downloads/OSMC_TGT_rbp1_20150929.img of=/dev/rdisk3s1 bs=1m
  • What should I do now?
Is 10.11 El Capitan?
We don’t support that yet
Thanks for the quick reply Sam.
Some drastic changes were made to the ‘Disk Utility’ app in El Capitan, I guess that’s what’s causing the installer app to act up.
PS : Thanks for all your hard work and support over the years!
We will fix OS X El Capitan support soon enough. it is tricky for me as I don’t have direct access to a Mac
I hope you will find a solution to fix the installer soon Sam, more and more like us will upgrade to 10.11 in the upcoming days. We all want to enjoy the September release.
BR.
Xavier
I have fixed the issue in Git, but I have no Mac at hand to compile the new installer on.
Waiting on this too.
If you were to provide instructions on how to compile on a mac, I could give it a shot.
This post is over a year old. Please start a new one if you are experiencing issues.
There were some problems with macOS Sierra, but the latest installer has support for it. If you continue to have problems, upload a full log.
Oh oops didn’t notice. Was trying to be a good citizen and searched before posting.
Saw it’s the same issue.
Will open a new thread.
Where are the logs for the installer? (this post doesn’t mention those: How to submit a useful support request)
Check out Testing OS X installer - #32
Please describe your OS X environment as much as possible.
Hey, sorry, I dove into some output of diskutil and saw some weird stuff. Turns out the problem was with the physical micro-sd card to sd card adapter (contact issue with the RO toggle; it was not on RO, but read as if it was)
Glad you got it solved
