Is there a way to install a launcher on the Vero 4K? I would like to have access to more things then just Kodi and can only think of using a launcher to do so. I am not sure how that works and if that will remove the auto updates of the Vero 4K. Any help would be appreciated.
Op seems to be confused and think that OSMC operates on/like Android OS, in that a launcher is essentially like a desktop or the GUI of your smart phone. OSMC is actually built on Debian Linux and does not include a desktop environment as that is a bit outside the scope for the use it was designed for. A desktop environment could possibly be installed, I think there is a thread here somewhere, but op may be less than impressed if he expects typical mobile apps to be available as they are on Android or iOS.
You are correct. I was assuming Vero 4K was an android OS but it sounds like it is not there fore it is not possible. I was trying to get some kind of launcher so I could use chrome browser and other stuff on it if I wanted to but that doesn’t sound possible. Thanks for the info.
