i want to create an access point using a rtl8188CUS chipset wifi dongle in Pi2. i already did this in raspbian jessie
but when i do the this in osmc, i can see AP name but cant be connected.
i googled a little and found that the main problem is connman. so i want to remove it and install isc-dhcp-server instead.
i am newbie in linux so any advise will be appreciated
i resolved my problem my self
but there is a problem
i want to change my Access Point Password and state from kodi GUI and for this purpose i must change a file hostapd.conf
so how do i create a plugin or add-on for this.does osmc have privilage to change a file in root folder and please give me a clue
thank you in advance
It sounds like you are trying to do something like this?
I think you should be able to change root files through ssh. You likely need to use the “sudo” keyword, and possibly change permissions (temporarily) on the file.
thanks berto i had solved AP issue but my problem is now i want to change AP ssid name and wpa-passphrase from osmc not from ssh shell
i wrote a python that parse hostapd.conf,read variables and change specific variable in that file through an add-on.
my problem is giving path to that file as i figured out kodi just know its folder and does not have access to root(e.g /etc/hostapd/hostapd.conf). even though i am confused with kodi path when reading from its folder
(e.g what is address of “/home/osmc/.kodi/userdata/hostapd.conf” in “myaddon.py”)
if you want i can send you my add on
17:34:08 46.471146 T:1958179376 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
17:34:08 46.471203 T:1958179376 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
17:34:08 46.471264 T:1958179376 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
17:34:08 46.471325 T:1958179376 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
17:34:08 46.471386 T:1958179376 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
17:34:08 46.471497 T:1958179376 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
17:34:08 46.471603 T:1958179376 NOTICE: Local hostname: OSMC_SP
17:34:08 46.471668 T:1958179376 NOTICE: Log File is located: /home/osmc/.kodi/temp/kodi.log
