Collecting aubio>=0.4.8
Downloading aubio-0.4.8.tar.gz (465 kB)
|████████████████████████████████| 465 kB 9.3 MB/s
ERROR: Command errored out with exit status 1:
command: /usr/bin/python3 -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-6275thoc/aubio_c5e1c38129df49d4bcfbe22bbd61e479/setup.py'"'"'; __file__='"'"'/tmp/pip-install-6275thoc/aubio_c5e1c38129df49d4bcfbe22bbd61e479/setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' egg_info --egg-base /tmp/pip-pip-egg-info-2ka86q9g
cwd: /tmp/pip-install-6275thoc/aubio_c5e1c38129df49d4bcfbe22bbd61e479/
Complete output (321 lines):
WARNING: Value for purelib does not match. Please report this to <https://github.com/pypa/pip/issues/10151>
distutils: /usr/lib/python3/dist-packages
sysconfig: /usr/lib/python3.7/site-packages
WARNING: Additional context:
user = False
home = None
root = None
prefix = None
WARNING: Value for platlib does not match. Please report this to <https://github.com/pypa/pip/issues/10151>
command: /usr/bin/python3 /usr/local/lib/python3.7/dist-packages/pip/_vendor/pep517/in_process/_in_process.py build_wheel /tmp/tmpwzv1lp5d
cwd: /tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2
Complete output (273 lines):
Processing numpy/random/_bounded_integers.pxd.in
Processing numpy/random/_generator.pyx
Processing numpy/random/_mt19937.pyx
Processing numpy/random/bit_generator.pyx
Processing numpy/random/mtrand.pyx
Processing numpy/random/_common.pyx
Processing numpy/random/_bounded_integers.pyx.in
Processing numpy/random/_sfc64.pyx
Processing numpy/random/_pcg64.pyx
Processing numpy/random/_philox.pyx
Cythonizing sources
blas_opt_info:
blas_mkl_info:
customize UnixCCompiler
libraries mkl_rt not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
blis_info:
libraries blis not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
openblas_info:
libraries openblas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
accelerate_info:
NOT AVAILABLE
atlas_3_10_blas_threads_info:
Setting PTATLAS=ATLAS
libraries tatlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf/atlas', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
atlas_3_10_blas_info:
libraries satlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf/atlas', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
atlas_blas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf/atlas', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
atlas_blas_info:
libraries f77blas,cblas,atlas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf/atlas', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
blas_info:
libraries blas not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
blas_src_info:
NOT AVAILABLE
NOT AVAILABLE
non-existing path in 'numpy/distutils': 'site.cfg'
lapack_opt_info:
lapack_mkl_info:
NOT AVAILABLE
openblas_lapack_info:
NOT AVAILABLE
openblas_clapack_info:
libraries openblas,lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
flame_info:
libraries flame not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
atlas_3_10_threads_info:
libraries lapack_atlas not found in /usr/local/lib
libraries tatlas,tatlas not found in /usr/local/lib
libraries lapack_atlas not found in /usr/lib
libraries tatlas,tatlas not found in /usr/lib
libraries lapack_atlas not found in /usr/lib/arm-linux-gnueabihf/atlas
libraries tatlas,tatlas not found in /usr/lib/arm-linux-gnueabihf/atlas
<class 'numpy.distutils.system_info.atlas_3_10_threads_info'>
NOT AVAILABLE
atlas_3_10_info:
libraries satlas,satlas not found in /usr/local/lib
libraries satlas,satlas not found in /usr/lib
libraries satlas,satlas not found in /usr/lib/arm-linux-gnueabihf/atlas
<class 'numpy.distutils.system_info.atlas_3_10_info'>
NOT AVAILABLE
atlas_threads_info:
libraries ptf77blas,ptcblas,atlas not found in /usr/local/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib
libraries ptf77blas,ptcblas,atlas not found in /usr/lib/arm-linux-gnueabihf/atlas
<class 'numpy.distutils.system_info.atlas_threads_info'>
NOT AVAILABLE
atlas_info:
libraries f77blas,cblas,atlas not found in /usr/local/lib
libraries f77blas,cblas,atlas not found in /usr/lib
libraries f77blas,cblas,atlas not found in /usr/lib/arm-linux-gnueabihf/atlas
<class 'numpy.distutils.system_info.atlas_info'>
NOT AVAILABLE
lapack_info:
libraries lapack not found in ['/usr/local/lib', '/usr/lib', '/usr/lib/arm-linux-gnueabihf']
NOT AVAILABLE
lapack_src_info:
NOT AVAILABLE
NOT AVAILABLE
numpy_linalg_lapack_lite:
FOUND:
language = c
running bdist_wheel
running build
running config_cc
unifing config_cc, config, build_clib, build_ext, build commands --compiler options
running config_fc
unifing config_fc, config, build_clib, build_ext, build commands --fcompiler options
running build_src
build_src
building py_modules sources
creating build
creating build/src.linux-aarch64-3.7
creating build/src.linux-aarch64-3.7/numpy
creating build/src.linux-aarch64-3.7/numpy/distutils
building library "npymath" sources
Could not locate executable gfortran
Could not locate executable f95
Could not locate executable ifort
Could not locate executable ifc
Could not locate executable lf95
Could not locate executable pgfortran
Could not locate executable nvfortran
Could not locate executable f90
Could not locate executable f77
Could not locate executable fort
Could not locate executable efort
Could not locate executable efc
Could not locate executable g77
Could not locate executable g95
Could not locate executable pathf95
Could not locate executable nagfor
Could not locate executable frt
don't know how to compile Fortran code on platform 'posix'
creating build/src.linux-aarch64-3.7/numpy/core
creating build/src.linux-aarch64-3.7/numpy/core/src
creating build/src.linux-aarch64-3.7/numpy/core/src/npymath
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_internal.h
adding 'build/src.linux-aarch64-3.7/numpy/core/src/npymath' to include_dirs.
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/ieee754.c
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_complex.c
None - nothing done with h_files = ['build/src.linux-aarch64-3.7/numpy/core/src/npymath/npy_math_internal.h']
building library "npyrandom" sources
building extension "numpy.core._multiarray_tests" sources
creating build/src.linux-aarch64-3.7/numpy/core/src/multiarray
conv_template:> build/src.linux-aarch64-3.7/numpy/core/src/multiarray/_multiarray_tests.c
building extension "numpy.core._multiarray_umath" sources
Running from numpy source directory.
/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/system_info.py:2026: UserWarning:
Optimized (vendor) Blas libraries are not found.
Falls back to netlib Blas library which has worse performance.
A better performance should be easily gained by switching
Blas library.
if self._calc_info(blas):
Blas (http://www.netlib.org/blas/) libraries not found.
Directories to search for the libraries can be specified in the
numpy/distutils/site.cfg file (section [blas]) or by setting
the BLAS environment variable.
Blas (http://www.netlib.org/blas/) sources not found.
Directories to search for the sources can be specified in the
numpy/distutils/site.cfg file (section [blas_src]) or by setting
the BLAS_SRC environment variable.
/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/system_info.py:1858: UserWarning:
Lapack (http://www.netlib.org/lapack/) libraries not found.
numpy/distutils/site.cfg file (section [lapack]) or by setting
the LAPACK environment variable.
return getattr(self, '_calc_info_{}'.format(name))()
Lapack (http://www.netlib.org/lapack/) sources not found.
numpy/distutils/site.cfg file (section [lapack_src]) or by setting
the LAPACK_SRC environment variable.
Warning: attempted relative import with no known parent package
/usr/lib/python3.7/distutils/dist.py:274: UserWarning: Unknown distribution option: 'define_macros'
warnings.warn(msg)
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 349, in <module>
main()
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 331, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/usr/local/lib/python3.7/dist-packages/pip/_vendor/pep517/in_process/_in_process.py", line 249, in build_wheel
metadata_directory)
File "/usr/local/lib/python3.7/dist-packages/setuptools/build_meta.py", line 222, in build_wheel
wheel_directory, config_settings)
File "/usr/local/lib/python3.7/dist-packages/setuptools/build_meta.py", line 207, in _build_with_temp_dir
self.run_setup()
File "/usr/local/lib/python3.7/dist-packages/setuptools/build_meta.py", line 259, in run_setup
self).run_setup(setup_script=setup_script)
File "/usr/local/lib/python3.7/dist-packages/setuptools/build_meta.py", line 150, in run_setup
exec(compile(code, __file__, 'exec'), locals())
File "setup.py", line 447, in <module>
setup_package()
File "setup.py", line 439, in setup_package
setup(**metadata)
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/core.py", line 169, in setup
return old_setup(**new_attr)
File "/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "/usr/lib/python3.7/distutils/core.py", line 148, in setup
dist.run_commands()
File "/usr/lib/python3.7/distutils/dist.py", line 966, in run_commands
self.run_command(cmd)
File "/usr/lib/python3.7/distutils/dist.py", line 985, in run_command
cmd_obj.run()
File "/usr/local/lib/python3.7/dist-packages/wheel/bdist_wheel.py", line 299, in run
self.run_command('build')
File "/usr/lib/python3.7/distutils/cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/command/build.py", line 61, in run
old_build.run(self)
File "/usr/lib/python3.7/distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/command/build_src.py", line 144, in run
self.build_sources()
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/command/build_src.py", line 161, in build_sources
self.build_extension_sources(ext)
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/command/build_src.py", line 318, in build_extension_sources
sources = self.generate_sources(sources, ext)
File "/tmp/pip-wheel-r_w86nm6/numpy_6640b02477734bbfb9d4591cddde8cf2/numpy/distutils/command/build_src.py", line 378, in generate_sources
source = func(extension, build_dir)
File "numpy/core/setup.py", line 434, in generate_config_h
moredefs, ignored = cocache.check_types(config_cmd, ext, build_dir)
File "numpy/core/setup.py", line 44, in check_types
out = check_types(*a, **kw)
File "numpy/core/setup.py", line 291, in check_types
"install {0}-dev|{0}-devel.".format(python))
SystemError: Cannot compile 'Python.h'. Perhaps you need to install python-dev|python-devel.
ERROR: Failed building wheel for numpy
ERROR: Failed to build one or more wheels
File "/usr/local/lib/python3.7/dist-packages/setuptools/installer.py", line 75, in fetch_build_egg
subprocess.check_call(cmd)
File "/usr/lib/python3.7/subprocess.py", line 347, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['/usr/bin/python3', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpknoc7qdz', '--quiet', 'numpy']' returned non-zero exit status 1.
The above exception was the direct cause of the following exception:
File "<string>", line 1, in <module>
File "/tmp/pip-install-6275thoc/aubio_c5e1c38129df49d4bcfbe22bbd61e479/setup.py", line 100, in <module>
'tests': ['numpy'],
File "/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py", line 152, in setup
_install_setup_requires(attrs)
File "/usr/local/lib/python3.7/dist-packages/setuptools/__init__.py", line 147, in _install_setup_requires
dist.fetch_build_eggs(dist.setup_requires)
File "/usr/local/lib/python3.7/dist-packages/setuptools/dist.py", line 788, in fetch_build_eggs
replace_conflicting=True,
File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 768, in resolve
replace_conflicting=replace_conflicting
File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 1051, in best_match
return self.obtain(req, installer)
File "/usr/local/lib/python3.7/dist-packages/pkg_resources/__init__.py", line 1063, in obtain
return installer(requirement)
File "/usr/local/lib/python3.7/dist-packages/setuptools/dist.py", line 844, in fetch_build_egg
return fetch_build_egg(self, req)
File "/usr/local/lib/python3.7/dist-packages/setuptools/installer.py", line 77, in fetch_build_egg
raise DistutilsError(str(e)) from e
distutils.errors.DistutilsError: Command '['/usr/bin/python3', '-m', 'pip', '--disable-pip-version-check', 'wheel', '--no-deps', '-w', '/tmp/tmpknoc7qdz', '--quiet', 'numpy']' returned non-zero exit status 1.
WARNING: Discarding https://files.pythonhosted.org/packages/78/36/d61dbc5d38a4d8701118f09c24bafb990729f573f80bff045c445b35929e/aubio-0.4.8.tar.gz#sha256=452fb2297b3aca0355ba1d56fe72593f7a930b5e7072c86f89a8f2eea3e0f94b (from https://pypi.org/simple/aubio/). Command errored out with exit status 1: python setup.py egg_info Check the logs for full command output.
Collecting ledfx
Downloading ledfx-0.6-py3-none-any.whl (432 kB)
|████████████████████████████████| 432 kB 5.4 MB/s
Downloading ledfx-0.5-py3-none-any.whl (432 kB)
|████████████████████████████████| 432 kB 7.2 MB/s
Downloading ledfx-0.4-py3-none-any.whl (420 kB)
|████████████████████████████████| 420 kB 6.5 MB/s
Downloading ledfx-0.3-py3-none-any.whl (417 kB)
|████████████████████████████████| 417 kB 8.2 MB/s
Downloading ledfx-0.2.0-py3-none-any.whl (383 kB)
|████████████████████████████████| 383 kB 7.4 MB/s
ERROR: Cannot install ledfx==0.10.0, ledfx==0.10.1, ledfx==0.10.2, ledfx==0.10.3, ledfx==0.10.4, ledfx==0.10.5, ledfx==0.2.0, ledfx==0.3, ledfx==0.4, ledfx==0.5, ledfx==0.6, ledfx==0.7 and ledfx==0.9.2 because these package versions have conflicting dependencies.
The conflict is caused by:
ledfx 0.10.5 depends on aubio>=0.4.9
ledfx 0.10.4 depends on aubio>=0.4.9
ledfx 0.10.3 depends on aubio>=0.4.9
ledfx 0.10.2 depends on aubio>=0.4.9
ledfx 0.10.1 depends on aubio>=0.4.9
ledfx 0.10.0 depends on aubio>=0.4.9
ledfx 0.9.2 depends on aubio>=0.4.9
ledfx 0.7 depends on aubio>=0.4.8
ledfx 0.6 depends on aubio>=0.4.8
ledfx 0.5 depends on aubio>=0.4.8
ledfx 0.4 depends on aubio>=0.4.8
ledfx 0.3 depends on aubio>=0.4.8
ledfx 0.2.0 depends on aubio>=0.4.8
To fix this you could try to:
1. loosen the range of package versions you've specified
2. remove package versions to allow pip attempt to solve the dependency conflict
ERROR: ResolutionImpossible: for help visit https://pip.pypa.io/en/latest/user_guide/#fixing-conflicting-dependencies
Adding root to Audio Group
main: line 42: whiptail: command not found
LedFx is now installed. Please type ledfx to start.
If you have no audio devices in LedFx and you're on a Raspberry Pi, please run 'sudo raspi-config' and setup your audio device (System Devices -> Audio)
