I would like to use OSCM on a Sony PVM for watching old 4:3 content, or scaled down HD content. What is the best way to do it?
I have both VGA 666 and SCART to Pi. I added a few lines from CRT PI boot config regarding the timmings and resolution and I successfully entered the installation screen @ 240p with OSCM, but when the installation finished it went out of sync and no image. I inspected the config and it changed everything I added initially. I also see that there is a VGA666 overlay in the overlay folder but how to use it, especially at 15 kHz? Any ideas? Thanks!
Note that on an update of the system, config.txt will be over-written. Use config-user.txt for any customisations.
If you post logs (use the command line and grab-logs -A) we can get a better picture of where you are.
reproduce the issue
