Installing Rsync failing
Hello,
I am just trying to get rsync installed on OSMC. I have tried sudo apt-get install rsync
or from root just apt-get install rsync
I get the following:
Reading package lists… Done
Building dependency tree
The following packages will be REMOVED:
ssh-app-osmc
rsync
0 upgraded, 1 newly installed, 1 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/380 kB of archives.
After this operation, 535 kB of additional disk space will be used.
(Reading database … 25215 files and directories currently installed.)
Removing ssh-app-osmc (1.2.3) …
Removing ‘diversion of /etc/ssh/sshd_config to /etc/ssh/sshd_config.distributed by ssh-app-osmc’
dpkg-divert: error: rename involves overwriting ‘/etc/ssh/sshd_config’ with
different file ‘/etc/ssh/sshd_config.distributed’, not allowed
dpkg: error processing package ssh-app-osmc (–remove):
subprocess installed post-removal script returned error exit status 2
ssh-app-osmc
Does anyone know what I am doing wrong?
Thanks in advance!
Danno
My guess is that you’ve installed something that’s conflicting. What’s the content of your /etc/apt/sources.list
And of course, logs would help:
So, in summary:
  • activate the logging
  • reboot the OSMC device
  • upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Here is the content of my sources.list
deb Index of /debian stretch main contrib non-free
deb Index of /debian stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
deb http://apt.osmc.tv stretch main
Here are the logs:
https://paste.osmc.tv/zagefenolo
It looks like you may have tried to un-install ssh (ssh-app-osmc). Is that the case?
You could try to install it again:
$ sudo apt install ssh-app-osmc
Are you using ssh to connect to your Pi now?
Yes I am SSH’d into it now but you are onto something. When I first started trying to get rsync installed, I tried to SSH into the OSMC with Putty. I got an error about not being able to agree on a key algorithm. So I tried to uninstall and reinstall SSH via OSMC Apps. Now when I look at OSMC apps, it indicates that SSH is NOT installed but clearly it is because I am SSH’d into it currently.
I will try to install it via terminal
You may have on old version of Putty. Make sure it’s up to date.
Trying to install it from terminal:
ssh-app-osmc is already the newest version (1.2.3).
Need to get 0 B/3168 B of archives.
After this operation, 0 B of additional disk space will be used.
root@basementosmc:/#
I can run it over and over but it still gives me the above message. Installing rsync is still giving me the same messages as well. If I try it via OSMC apps, it says it installs but then it doesn’t show installed.
Thanks,
Danno
Sorry, meant to mention that. Yes, upgrading Putty got me SSH’d into it but now its a weird deal where OSMC doesn’t think its installed…
what does sudo apt-get install -f do?
Here is the result of apt-get install -f
apt-get install -f
ssh-app-osmc
0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
After this operation, 38.9 kB disk space will be freed.
Do you want to continue? [Y/n] Y
ssh-app-osmc
Ok, I think we have seen this issue before. You can try
sudo apt-get install --reinstall ssh-app-osmc
but not sure if that succeed.
That did it! I can’t thank both of you enough for getting this resolved so quickly!
Thanks again!
Danno
Great!
