Intermittent problem: Kodi not coming out of screensaver dimming
I’ve recently experienced a problem with my Vero V running Arctic Fuse 2 skin (if that’s relevant): after a period of time my screen dims as per the screensaver setting, but occasionally it won’t return to proper brightness at all and I need to reboot to fix. I can navigate around, play videos, all the usual stuff, it’s just the screen stays dim.
It’s intermittent, seemingly random, and I can’t reproduce it at will. As such I don’t have a log to paste, at least not yet.
Anyone got any ideas? I haven’t seen this before.
Hi, first question: Does it also stay dimmed, if you use the skins ‘OSMC skin’ and/or ‘Estuary’?
Fair question, and the short answer is I don’t know. It’s so intermittent I could go a week or more without it happening, so I haven’t tried different skins. I guess I should at least try that and see.
I appreciate I’m not giving you much to work with here!
Ik have the same problem with my Ugoos with CoreElec, and sometimes with my Vero V. So probably a Kodi-issue, not specific Vero. Reboot always helps, have not found any other way to stop the dimming, starting a movie doesn’t help either.
May I ask what skin you’re using, pameijer?
I use Aeon Nox on both devices.
I also use Arctic Fuse 2 and have experienced this. There’s an issue for it which points to it being an issue in Kodi.
I have worked around it by disabling automatic updates to the skin. Since doing this, I haven’t seen the issue and can update the skin when I want to.
Excellent find, thank you so much!
It’s just happened again, and I can see in the log that the skin seemed to load/reload a couple of hours ago. If it’s useful for me to share that log I can do so, but I’m not sure what the rules are here about logs that refer to illegal add-ons…
Either way, this seems to corroborate the suggestion above.
Has happened fairly often on my vero v too using standard skin. Always just reboot to get normal brightness back.
