I have two raspberries, RPIB with raspbian as an OS (pi user), and RPI2 wih osmc as an OS (osmc user).
I have made two tests.
The first test is iperf server on RPI2 and client on RPIB.
osmc@osmc:~$ iperf -s
Server listening on TCP port 5001
TCP window size: 85.3 KByte (default)
[ 4] local 192.168.5.50 port 5001 connected with 192.168.5.60 port 58922
[ ID] Interval Transfer Bandwidth
[ 4] 0.0-10.0 sec 53.9 MBytes 45.0 Mbits/sec
pi@raspberrypi:~ $ iperf -c 192.168.5.50
Client connecting to 192.168.5.50, TCP port 5001
TCP window size: 43.8 KByte (default)
[ 3] local 192.168.5.60 port 58922 connected with 192.168.5.50 port 5001
[ 3] 0.0-10.0 sec 53.9 MBytes 45.0 Mbits/sec
If I swithc the sides I get different results:
pi@raspberrypi:~ $ iperf -s
[ 4] local 192.168.5.60 port 5001 connected with 192.168.5.50 port 49726
[ 4] 0.0-10.0 sec 97.8 MBytes 81.6 Mbits/sec
osmc@osmc:~$ iperf -c 192.168.5.60
Client connecting to 192.168.5.60, TCP port 5001
[ 3] local 192.168.5.50 port 49726 connected with 192.168.5.60 port 5001
[ 3] 0.0-10.0 sec 97.8 MBytes 81.9 Mbits/sec
I have executed tests several times and result is always the same.
Can someone explain the difference in the speed?
Original Raspberry Pi 1 ?
Kodi is running on OSMC during the test ?
If so, that is why. The mere act of having Kodi running on a Pi 1 consumes enough CPU time to drop Ethernet throughput to about half of the maximum possible. The Pi 1 just has a really slow CPU.
Try stopping Kodi then re-run your test:
Also if you are really trying to directly compare the performance of the two Pi’s you should not be testing between them but to a 3rd much faster machine such as a PC. Otherwise you are testing the sending performance of one Pi at the same time as the receiving performance of the other and vica versa - you will not be able to get meaningful results by doing that as you will not know which Pi is causing the issue.
After stopping kodi on osmc (192.168.5.50) the results are still disbalanced.
raspbian server
root@raspberrypi:/home/pi# iperf -s
[ 4] local 192.168.5.60 port 5001 connected with 192.168.5.50 port 45372
[ 4] 0.0-10.1 sec 89.0 MBytes 74.1 Mbits/sec
[ 5] local 192.168.5.60 port 5001 connected with 192.168.5.50 port 45374
[ 5] 0.0-10.0 sec 97.6 MBytes 81.5 Mbits/sec
[ 4] local 192.168.5.60 port 5001 connected with 192.168.5.50 port 45376
[ 4] 0.0-10.0 sec 95.8 MBytes 80.0 Mbits/sec
osmc client
root@osmc:/home/osmc# iperf -c 192.168.5.60
[ 3] local 192.168.5.50 port 45372 connected with 192.168.5.60 port 5001
[ 3] 0.0-10.0 sec 89.0 MBytes 74.5 Mbits/sec
[ 3] local 192.168.5.50 port 45374 connected with 192.168.5.60 port 5001
[ 3] 0.0-10.0 sec 97.6 MBytes 81.9 Mbits/sec
[ 3] local 192.168.5.50 port 45376 connected with 192.168.5.60 port 5001
[ 3] 0.0-10.0 sec 95.8 MBytes 80.2 Mbits/sec
osmc server
root@osmc:/home/osmc# iperf -s
[ 4] local 192.168.5.50 port 5001 connected with 192.168.5.60 port 59546
[ 4] 0.0-10.0 sec 53.6 MBytes 44.8 Mbits/sec
[ 5] local 192.168.5.50 port 5001 connected with 192.168.5.60 port 59547
[ 5] 0.0-10.0 sec 53.4 MBytes 44.6 Mbits/sec
[ 4] local 192.168.5.50 port 5001 connected with 192.168.5.60 port 59548
[ 4] 0.0-10.1 sec 53.5 MBytes 44.6 Mbits/sec
respbian client
root@raspberrypi:/home/pi# iperf -c 192.168.5.50
[ 3] local 192.168.5.60 port 59546 connected with 192.168.5.50 port 5001
[ 3] 0.0-10.0 sec 53.6 MBytes 44.9 Mbits/sec
[ 3] local 192.168.5.60 port 59547 connected with 192.168.5.50 port 5001
[ 3] 0.0-10.0 sec 53.4 MBytes 44.6 Mbits/sec
[ 3] local 192.168.5.60 port 59548 connected with 192.168.5.50 port 5001
[ 3] 0.0-10.0 sec 53.5 MBytes 44.7 Mbits/sec
While on osmc media center is stil down rsync confirms the speed difference.
from raspbian to the osmc, external hdd to external hdd
root@raspberrypi:# rsync -aPhv tails-i386-2.0.iso osmc@192.168.5.50:/mnt/wde4tb/za_brisati
sending incremental file list
tails-i386-2.0.iso
1.14G 100% 2.34MB/s 0:07:42 (xfr#1, to-chk=0/1)
sent 1.14G bytes received 35 bytes 2.45M bytes/sec
total size is 1.14G speedup is 1.00
from osmc to the raspbian, external hdd to external hdd
root@osmc:/mnt/wde4tb/za_brisati# rsync -aPhv tails-i386-2.0.iso pi@192.168.5.60:/mnt/wdg2tb/obrisi
tails-i386-2.0.iso
1.14G 100% 1.79MB/s 0:10:03 (xfr#1, to-chk=0/1)
sent 1.14G bytes received 35 bytes 1.85M bytes/sec
On both raspberries RPI1 (raspbian) and RPI2 (osmc) I have installed samba. I have copied the same file 1.05 GB from raspbian to my laptop (windows 10) which was at approximatelly speed 4.15 MB/s. The same file from osmc to laptop was copied at average speed 5.30 MB/s.
I really don’t get it.
What sort of switch are your Pi’s connected to ? Is it a managed or unmanaged switch ?
If it is a managed switch do you have Ethernet flow control enabled or disabled on the ports the Pi’s are connected to ?
Try either enabling flow control on the switch ports the Pi’s are connected to, or add the following option to /boot/cmdline.txt:
smsc95xx.turbo_mode=Y
