I had implemented an IPTABLE Killswitch with OpenVPN at this link KillSwitch
This solution has been working great, however when the OPENVPN fails and the kill switch starts blocking traffic, there is no way to know without manually checking.
I would like some help in developing a script or solution that can detect when their is not an IPaddress, then run script to restart OpenVPN.
My thoughts would be the script would occassionally run:
curl ipinfo.io/ip
If returns result
Then exit
else
sudo systemctl stop openvpn
sudo systemctl start openvpn
This seems easy enough in concept but I don’t know where to start writting the script in OSMC or if there is an easier solution.
#!/bin/bash
# Test an IP address for validity,
function valid_ip()
local ip=$1
local stat=1
if [[ $ip =~ ^[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}\.[0-9]{1,3}$ ]]; then
OIFS=$IFS
IFS='.'
ip=($ip)
IFS=$OIFS
[[ ${ip[0]} -le 255 && ${ip[1]} -le 255 \
&& ${ip[2]} -le 255 && ${ip[3]} -le 255 ]]
stat=$?
fi
return $stat
MYIP=$(curl -s http://ipinfo.io/ip)
if valid_ip $MYIP; then
fill in what you like
else
fill in the other option
fi
