it worked and all of the sudden stopped working. Reinstalled osmc twice but no luck.
I have a working itv address and finds the channels but when I press says “working” for a second then nothing.
Log here:
Log here:
Not a debug log, so can’t see much.
From what I do see, looks like an issue with the IPTV provider. Have you asked them?
We can’t provide support for those streams as we are not in control of that content.
Understand , I thought that was a debug log.
The thing is that line works on kodi installed on my computer , just not on the raspberry osmc.
I will try to get a log .
What’s the error 404 that shows on there ?
Not sure, but I’m guessing your IPTV provider has a problem.
404 usually means not found, but none of the resources that are failing are provided by us.
I’d suggest asking them about the problem. I am sure they can test a Pi with OSMC and investigate the issue. I suspect they’ll have a Pi around for testing purposes.
