I’m using IPTV Simple PVR client to stream from network.
Since OSMC upgrade to 2023.01-1 I get this error: CCurlFile::Open failed with code 404 fetching a png, and CCurlFile::Open failed with code 401 opening a stream
Here’s the full error message in kodi.log:
2023-03-12 14:09:10.442 T:3112 ERROR <general>: CCurlFile::Exists - Failed: Failure when receiving data from the peer(56) for http://<path_to_stream>/5412
2023-03-12 14:09:10.529 T:3112 INFO <general>: Skipped 1 duplicate messages..
2023-03-12 14:09:10.529 T:3112 INFO <general>: AddOnLog: pvr.iptvsimple: pvr.iptvsimple - GetChannelStreamProperties - Live Stream URL: http://<path_to_stream>/5412
2023-03-12 14:09:10.543 T:3112 INFO <general>: VideoPlayer::OpenFile: pvr://channels/tv/Alle%20Kan%c3%a4le/pvr.iptvsimple_1318614339.pvr
2023-03-12 14:09:10.546 T:3722 INFO <general>: Creating InputStream
2023-03-12 14:09:10.721 T:3722 ERROR <general>: CCurlFile::FillBuffer - Failed: HTTP returned error 401
2023-03-12 14:09:10.721 T:3722 ERROR <general>: CCurlFile::Open failed with code 401 for http://<path_to_stream>/5412:
2023-03-12 14:09:10.825 T:3722 ERROR <general>: CCurlFile::FillBuffer - Failed: HTTP returned error 401
2023-03-12 14:09:10.825 T:3722 ERROR <general>: CCurlFile::Open failed with code 401 for http://<path_to_stream>/5412:
2023-03-12 14:09:10.825 T:3722 ERROR <general>: CFileCache::Open - <http://<path_to_stream>/5412> failed to open
2023-03-12 14:09:10.825 T:3722 ERROR <general>: CVideoPlayer::OpenInputStream - error opening [pvr://channels/tv/Alle%20Kan%c3%a4le/pvr.iptvsimple_1318614339.pvr]
2023-03-12 14:09:10.825 T:3722 INFO <general>: CVideoPlayer::OnExit()
2023-03-12 14:09:10.840 T:3112 INFO <general>: Loading skin file: DialogConfirm.xml, load type: KEEP_IN_MEMORY
2023-03-12 14:09:10.850 T:3112 INFO <general>: CVideoPlayer::CloseFile()
2023-03-12 14:09:10.883 T:3112 INFO <general>: VideoPlayer: waiting for threads to exit
2023-03-12 14:09:10.883 T:3112 INFO <general>: VideoPlayer: finished waiting
I cannot reproduce this issue on PC using VLC, and this indicates a device specific error.
What other information is required from log?
I pasted all that is written to log in the relevant time window.
I have verified other streaming URL w/o authentication, and there’s no issue.
This confirms that addon IPTV Simple PVR client generally works, but it fails if URL includes authentication, means http://<path_to_provider>:8080/<user>/<password>/18392
I have flashed OSMC version 20221001 on my Vero 4k and started setup from scratch.
I can report that IPTV Simple PVR works before running sudo apt dist-upgrade.
This means the root cause of this issue is not the *.m3u file and it’s content, because this file has not changed.
And there’s no restriction of streaming provider to block Kodi.
Instead the root cause must be related either to addon IPTV Simple Client and/or Kodi; I’m currently using IPTV Simple Client version 19.2.2 and Kodi version 19.4.
Run the following command to add the staging repository: echo 'deb http://apt.osmc.tv bullseye-devel main' | sudo tee /etc/apt/sources.list.d/osmc-devel.list
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command: sudo rm /etc/apt/sources.list.d/osmc-devel.list.
Running apt-get dist-upgrade will add more than just one file.
And if I want to revert, I need to downgrade the relevant packages.
This is a lot of manual work.
