Loading a big m3u file seems successful, thousands and thousands of these lines:
DEBUG : AddOnLog: pvr.iptvsimple: pvr.iptvsimple - LoadPlayList - M3U line read: ‘#EXTINF:-1 tvg-id="" tvg-name=“✦●✦ [NL] ALGEMEEN [FHD] ✦●✦” tvg-logo="" group-title=“EU | NETHERLANDS FHD”,✦●✦ [NL] ALGEMEEN [FHD] ✦●✦’
2021-07-07 18:43:40.743 T:2680 DEBUG : AddOnLog: pvr.iptvsimple: pvr.iptvsimple - AddChannelGroup - Added group: EU | NETHERLANDS FHD, with uniqueId: 49
Then when opening ¨TV¨
2021-07-07 19:25:09.933 T:2612 INFO : Loading skin file: MyPVRChannels.xml, load type: KEEP_IN_MEMORY
It just blocks the screen and showing 1 cpu load of 142…
Ssh is stil working, but the gui is frozen.
Reduce channel list or disable epg. Sounds like the vero4k has ran out of memory.
Thanks Tom.
I tried with smaller lists, same problem.
EPG is not being used.
1989 M total memory
793 M used memory
776 M active memory
427 M inactive memory
572 M free memory
25 M buffer memory
598 M swap cache
0 M total swap
0 M used swap
0 M free swap
0 pages swapped in
0 pages swapped out
reproduce the issue
I just opened the m3u file with a text editor and cut out all except the channels for my country. It is loading fine now. The original m3u file was 58 MB.
wow, that will eat up alot of memory. Like each line holds 2-3 urls, stream icon and sometime epg
