Hi All.
Just setup the Vero 4K - everything went without a hitch, impressive little box.
The included remote works well but I want to run IR since I use URC remotes - in this case an MX-980 which connects to an URC MSC-400 in a media closet. All of my devices are in that closet and connect to the 4 TVs in the house via an 8x8 HDMI Matrix Switcher. This device will go in there as well - hence the need to have IR.
The IR Receiver built into the unit responds well enough but I figured I would try the extender as a possible option. I plug into the outer most 3.5 mm jack but it does not seem to respond to the remote. I have confirmed using IRW - the internal one works but if I cover it and point at the extender it does not respond.
In the OSMC config I have it set up to use an MCE remote since that is what I have programmed into the MX-980. They are all the same codes that i use with my Intel NUC and RPi3 each running Kodi.
So, AFAICT, it is the extended that is not working. Anything I might be missing?
Ernie
