Hi all, after the last update I did in, I believe November, my infrared remote control stopped working for OSMC on my raspberry pi.
Checking the status through putty with systemctl status lircd.service
returns Unit lircd.service could not be found.
When trying to reinstall LIRC i get following error:
root@osmc:~# sudo apt-get install lirc
Reading package lists... Done
Building dependency tree
The following additional packages will be installed:
libftdi1-2 libjack-jackd2-0 liblirc-client0 liblirc0 libopus0 libportaudio2 libusb-1.0-0
Suggested packages:
jackd2 opus-tools lirc-compat-remotes lirc-drv-irman lirc-doc lirc-x setserial
Recommended packages:
gir1.2-vte-2.91 python3-yaml
The following packages will be REMOVED:
armv7-eventlircd-osmc armv7-lirc-osmc armv7-remote-osmc rbp2-device-osmc
libftdi1-2 libjack-jackd2-0 liblirc-client0 liblirc0 libopus0 libportaudio2 libusb-1.0-0 lirc
0 upgraded, 8 newly installed, 4 to remove and 0 not upgraded.
Need to get 0 B/1251 kB of archives.
After this operation, 3192 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 37165 files and directories currently installed.)
Removing rbp2-device-osmc (1.5.7) ...
WARNING: You have tried to remove a package that is essential to OSMC's operation.
To undo these changes, run 'sudo apt-get -f install'.
dpkg: error processing package rbp2-device-osmc (--remove):
installed rbp2-device-osmc package pre-removal script subprocess returned error exit status 1
dpkg: armv7-lirc-osmc: dependency problems, but removing anyway as you requested:
armv7-remote-osmc depends on armv7-lirc-osmc.
armv7-eventlircd-osmc depends on armv7-lirc-osmc.
Removing armv7-lirc-osmc (0.9.4-6) ...
dpkg: armv7-remote-osmc: dependency problems, but removing anyway as you requested:
rbp2-device-osmc depends on armv7-remote-osmc.
Removing armv7-remote-osmc (1.2.4) ...
Removing 'diversion of /etc/lirc/lircd.conf to /etc/lirc/lircd.conf.distributed by armv7-remote-osmc'
Removing armv7-eventlircd-osmc (1.4.6) ...
rbp2-device-osmc
Any idea what’s going on and how i can fix it ?
